No specific design or last but looking for something in burgundy or museum brown. Starting a gmto anytime soon ?
Well... ok... Hmmm
Here's some general sizing advice for you, hope it comes in handy.
He has a series of 5 main lasts for the Argentum range.
The Hawksbill (banana shaped, almond-ish toe), the Soft Square, the Chisel 1 and 2, and the Argentum Round.
There is another roundish last (Argentum Last B) that he developed mainly for boots. I will leave out this last.
In terms of fit, the Hawksbill and Soft Square are the slimmest / narrowest and almost always would require a half size up from your normal size.
The Argentum Round last I feel is the most generous, is wider at the toe box, but has an equivalent instep, but is a little longer than the Hawksbill. For more narrow footed, lowish instep guys, this would probably work for you in your normal size.
The Chisel 1 and 2 fit identically, the only difference being the toe shape. And is somewhat in between the Round last, and the Hawksbill.
I am not planning any GMTOs at the moment, but if there are sufficient interests, or if you have any ideas, I can help to organise / run point if you want. Or better yet, I can help with the organisation, and then refer the entire GMTO to Antonio via Yeossal, since he is the official Singapore distributor, and he's an honest, nice guy.
Although Yeossal does not have a retail shop, if any of you guys have genuine interest in the shoes and would need a test fit, I would encourage you guys to contact him to see if an off-the-cuff meet up can be arranged. I am sure he would try his best to help.
