Working Shoe for Young Exec - Part 3
blzy333
My penny loafers was tight too when I got them. More on the width area which I was told its alot harder to 'expand' as compared to length wise.
After a few initial painful wears it fits better now. Try using a slightlyyyy bigger shoe tree
I just bought a pair of leather penny which felt abit tight but I am not sure...how do y'all tell if your loafers are too tight? there's no allowance at the heel when i try to push my foot forward but there's not much discomfort when I tried on the shoes too. Dk if i should change half size bigger :/
cokiee
If there's not much discomfort then should be fine I think. If leather over time it'll expand. Also remember than penny loafers don't have laces which allow you to tighten so it needs to be a bit tighter.
noobiee
Guys, i have recently purchased a double monk carlos santos from pediwear website and have received the shoes
however i notice there are several defects as per below photos. just want to check with the laojiaos here on any solution or i have to return the shoes..
this defect is the one i cannot accept the most, a 0.5cm discoloration at the back of the shoes.. is there any way to remove it?
Many brown dots inside the shoes? water damage?
a cut
a 0.5cm dent and 1cm scratch..
discoloration?
a round blemish??
thanks alot.
thundermarch
@noobiee.
Sorry to hear that. I do agree that it's sometimes a little annoying to find defects in your shoes.
Given that CS does a lot of their own custom patina work, you'll probably get a lot of variation between pairs, and I think the discoloration at the heel is a result of that. Small mistakes can be made and you might get splotches. If it's any consolation, I don't think it'll be very noticeable when you wear them. But there isn't any quick fix of your own. You can try burnishing the heel area with dark brown cream and wax to make it less obvious but to completely eliminate it you probably will need to engage a pro to re-dye the whole pair.
The third pic shows a scratch with a defect in the grain surface. Might be from poor handling by the factory, retailer, or somewhere along the process. Hard to say. This is probably something you can bring up to the retailer.
The marks on the lining don't look like water damage. In fact, lining leather is going to be subject to sweat exposure almost all the time when the shoes are worn. The marks might be some kind of dye.
That being said, I think you can just drop a friendly email to the retailer highlighting your concerns. I don't really think the defects (except for maybe picture 3) are very out of the ordinary for shoes in that price range. But most retailers are willing to come to some kind of agreement. Perhaps an exchange.
Best of luck.
noobiee
@noobiee.
Best of luck.
Thank you so much for the detailed reply, i have dropped an email to pediwear with the photos and my concern.. hopefully i can get it exchange for a new one, i really like this pair alot haha
suitboy
USA
Anyone can recommend any brands in US? Will be roadtripping several states in US during April-May period.
Preferably below $400 SGD a pair. Current list only has Allen Edmonds oh god.
RayeAng
Dress shoes - Alden / c&j ( not really us brand but I think u might be able to find some good deals there.)
Work boots - red wings / thorogoods
jack27
Hi.. Thinking to apply Vibram sole on my Loake and Carlos Santos shoes.. Any suggestion? where to get? TIA
patryn33
Alden starts at usd$450+ a pair b4 tax
https://www.theshoemart.com/alden-shoes/?CAWELAID=120324390000011386&CATRK=SPFID-1&CAAGID=50233889253&CATCI=kwd-302020206461&CAPCID=268971858913&CADevice=m&gclid=Cj0KCQiAjszhBRDgARIsAH8KgvcKpCnmeBglrZPrOTkctPxGYBlNlVuuupcJJancw0dR0IeZTLv-ApMaAr8qEALw_wcB&sort=priceasc
Oakstreet also above budget
https://oakstreetbootmakers.com/footwear
U can try https://www.rancourtandcompany.com too
Allen Edmond if u don’t mind visiting the factory @ Port Washington can get 2pairs under sgd$400. Prices u can check shoe bank.com.
Not GYW but make in USA https://johansen.usmadeshoes.com/collections/mens
Boots - Thorogood, red wings, Chippewa all within budget
If u visit red wing MN, maybe can score 2 pairs.
Not as high quality but https://www.brooklynboot.com
Dybala
just wondering if this can be used as formal shoes, want to try something different
