Working Shoe for Young Exec - Part 3
thatshoeotaku
FWIW, I've had a couple pairs of Church custom grade and I will rank the leather quality a notch above C&J bench grade (I've got no experience with C&J hand grades) but below that of EG..
No expert at construction but IIRC they don't do hidden channels or beveled waists unless at the "top of the top" range.
Designs are subjective but I personally prefer C&J which are more contemporary..
I believe current rates for custom grades are starting $900.. a lot of $$....
I honestly believe that at the church's and c&j level there's practically no difference in leather quality. It's almost down to luck, you can get a really good piece if the clicker so happens to use the butt.
Adding fabric interlining makes the leather crease more nicely but how many people can actually tell if a interliner is used on their shoes?
bjornng
exterminazn
Anybody have suggestion for durable Mocassin kinda design shoes?
Budget max $200
runningman.snsd
What’s a good entry level penny loafers to buy?
Budget is Value for money, if 300-400 also okay so long it’s worth the price
espressoull
You may check out The Quarters new RTW line, which has 2 loafers in the collection - Tasseled Loafers & Penny Loafers. Their shoes are at $399.
espressoull
thank you for your reply bro! well noted, added to cart already. haha
what cream polish do you use bro? sapphir?
was just thinking if kiwi polish would suffice. hahah
I've used both brands before, and definitely recommend Saphir for their leather care products, quality and easy to use products for shoe care needs.
jonleelk
Recommend to start with shoe cream from either sapphir (they have 2 ranges)
or Collonil.
craft-inc_sis-car-1909supremecreme
Zon
Had a very good read here.
Realised most of my shoes are cemented and no wonder it always doesn't last.
Need some advise please. I found a few MTO for like 250+, in the first page. Seems reasonable.
However, I travel a lot in this region. Thailand, viet, Indo, India, aus are some of the more freq travels.
Does these have more value MTOs or ready made brands?
twomantoes
If you like chunky shoes then you'll probably like them. Have a look at the other makers available locally at that price point and see which lasts you prefer.
At 700+(or a bit more) there are tons of options available out there that I personally feel are much better looking and have better quality than Church.
I see, I was thinking of getting a second hand one from carousell to try and see how. Any advise for that?
darthsid11111
Fugashin in HCM and Sagara Boots in Indo
Sent from Samsung SM-N960F using GAGT
Zon
Thanks darthsid. Will check out. Seems to be usd230+, within budget. Is this better value than the locals?
Btw, I started reading this thread as I had an old leather shoe that is very comfortable. Realized it wasn't cemented so its more lasting.
Did my first ever medium brown shoe cream.
Sent from HUAWEI LYA-L29 using GAGT
Which shoe cream u applied ~ the result very nice
wiz
TheSabot is having a good sale now, 50% for AM, if sizes are available don’t wait!
darthsid11111
Personally I would either buy local in order to get serviced at a physical shop, or Loake's 1880 range can't be beaten at the $300+ price range.
