Working Shoe for Young Exec - Part 3
tyh1991
Update on the post I made on Rozsnyai shoes previously.
Just received their dress boots today. For you guys to consider wearing boots with formal attire :)
wahjohreno
That’s quite the sleeper!
Looks like a regular pair of oxfords when you stand up, but when you sit down, people are going to know you’re quite the dandy!
jonchar
morning all, noob here.
Bought 2 pairs of shoes from Bern at Suntec and just tried them both and they cut into my ankle badly. Prior to this, I was wearing Geox and it requires no breaking in at all with no issues even when out of the box.
Can I know if it will be better after a few times after breaking in? Or should I get something new like from CNES? Will it be better?
Thanks.
Force89
Hi,
Looking for someone else to share the Jonathan Abel 1 for 1 promo. PM me if interested!
wahjohreno
Thanks.
Entry level leather shoes tend to take a longer period to break in.
For example, my Crockett & Jones might take 5 wearings to feel like a second skin. But I have a pair of Ed Et Al loafers that literally took one year to feel comfortable.
So it really depends on the leather quality.
jonchar
Ok thanks. Guess I have to soldier on for now.
All in a Day
If u didnt get a good fitting pair, which is a function of your feet shape/type vs the shoe last, there is no breaking in to speak of. Hope yours is not a fit issue to begin with..
jonchar
It can also be that the shape of the last is not suitable for your feet. Like it’s too narrow somewhere.
Haha all pointing to the fact I must get new ones. I’m already taking to someone to share the 1 for 2 for Jonathan Abel.
tyh1991
Thanks.
Which part of your ankle is hurting?
Just to share some stuff I learn from the guys over at George Cleverley regarding ankle pain when I was at their shop. Hopefully this can help some of you when buying shoes!
Ankle pain at the heel due to heel slip. Possible causes:
- Shoe isn't in the right size. (I know too big will cause this but I can't rmb if too small will too).
- If you are looking at loafers, how well the back of your shoes cup your heel. Too big and your shoes will simply slip as there isn't as much material holding your foot in.
- Your shoe hasn't been broken in at the sole. Goodyear welted (and possibly blake-stitched shoes with thicker soles) shoes feel stiffer at the start due to it's construction. Once your shoes are broken in most of the heel slip will go away (if it was not a sizing issue to begin with).
- Like others have pointed out poor quality leather might be really stiff and hard to break in. Very similar to the above symptom - the shoes do not bend readily when you walk thus causing heel slip.
- The size of the opening of your shoes. See the picture below - the shoe on the left has a much bigger opening than the one on the right. Depending on your feet structure, this might be an issue and major contributing factor to heel slip (there's less material holding your foot in). Your shoes can fit just nice when you're sitting down and trying the shoes, but as soon as you start walking you'll realize this issue straight away!
Some shoes have a cup like structure at the heel to provide some sort of heel support (possibly minimize heel slip? can't rmb if they mentioned this). See the below picture - the shoe at the front has a significant cup like structure wheras the one at the back has a straight design. If your heel and back of your feet is rather straight, this will obviously eat into your heel.
Heel height (and possibly the heel counter height too). Depending on your foot, the shoes might be cut too high at the heel region. See the attached picture. Similar to the above issue, this will eat into your heel.
Lastly the sides of your shoes can but cut too high. See the below picture - the shoe on the right is cut higher than the one on the left. This can be an issue if your ankle bone is rubbing against it.
Of course there can be more causes, but these are the one I picked up. Hope this can be helpful!
Lastly as asians we have very flat foot which can cause a huge number of fit issues, and ankle pain can be just one symptom of it. Maybe some shoe expert can elaborate on this. Luckily I've been blessed with a pair of feet that are very standard and easy to fit. :s12:
jonchar
Wow 5 stars answer. Thanks for the effort to type out everything and explain to me! Much appreciated on your reply. I guess I will go relook at another pair. It might be too tight for me. It cut at the side of the ankle causing it to bleed actually.
tyh1991
You can try get those heel cushions to elevate the heel area a little first.
But don't get too thick as it will make the instep (the shoe lace area) smaller which will create other fit issues.
rowrowroyce
Hello. Can anyone share which shoe brand will deliver this April? Like boots? Need for work shoe delivery job.
Dvoiddeckbench
Just like to share my experience purchasing from Jonathan Abel.
Great response by the team at Jonathan Abel via Whatsapp.
Purchased 2 pairs of Noah during the "buy 1 get 1 free" promotion. 2 pairs came within 2 days but I bought them a size bigger. Mailed out the shoes and received it 2 days after with my true size.
Was disappointed when I take the shoes out from the bag though. The left side looks outstanding but the right side looks like someone has worn it before. I could see crisp already formed.
I do not want to go through the hassel by sending back the shoes and just make do with it. The second pair will come after 12 weeks as they do not have the stock I want for my size at the moment.
Meanwhile I could just pray that the second pair will TRULY be a pair that has never been worn before.
Could not expect too much for 2 pairs of shoes for $350.
Posted from PCWX using because PCWX need 10 characters in order to post.
