XBOX One Controller
twlee88
guys..just got my xbox one controller.
its not as easy as it looks as some game are not compatible with it and need extra driver to make it works.
Im have some question on the controller and how you bros fix it?:
1) Playing some games like FFXIII, the controller will stop. read online and requires additional driver to make the device manager shows "Microsoft Xbox One Controller" instead of "Xbox Controller"..not sure the fix is the best or any of u bros try other method?
*updates*
by using the "Microsoft Xbox One Controller" driver, the vibration is not working
2) headphone jack...how to use it? need install or adjust anything? i plug in my headphone to it and it doesnt work...sorry for being noob here...:(
yusoffb01
*updates*
https://support.xbox.com/en-US/xbox-one/accessories/set-up-chat-headset
Phd123
*updates*
1) you need to download Xbox controller app from windows store. Log in, and it will help update to enable vibration.
2) for sound, plug in the earphones, and try going into sound settings and select headphones to default / enable.
twlee88
1) downloaded and updated my controller. if using "xbox controller" driver, it vibrates but cant play ffxiii...
if using "microsoft xbox one controller", it can play ffxiii but cant vibrate...
what driver are u bros using?
p.s. "microsoft xbox one controller" driver is not official microsoft driver, but it do fix the ffxiii game..its a fix after googling for solution.
2) noted. will test it tonight.:s12:
Phd123
Dunno what driver. I just followed manual instructions, auto plug and play on Win 10.
Hope works for you. Perhaps compatibility for full features only with some games. Maybe need to google for more tips.
