Xiaomi 13 series
Milo-Dino
tian_yibang
the cam really fugly
so squarish very obiang
anyway
imho XM or any cheena fones their hoot only worth up till $400-500 max ie. global redmi note series, poco, cheena K series, realme
anything beyond that price range might as well look at others
and for near or over $1K worth
i definitely rather get a samsuck flagship
ZhuTou!
anyway
Buy phone is based on specs/$ ratio. Buying a more common brand doesnt gives u extra benefits. They served the same purpose as a phone. U think by showing samsuck logo makes u more atas? Some ppl may even laff at u for paying extra just for the brand. As in chinese say, brand cannot eat.
salmonella
Has anyone bought and used china version xiaomi phone before? Any issues? Play store, ota updates, English language interface, default bloatware / spyware apps?
andyhtc
Suspended
On spyware, this can happen when using Chinese phones to share a joke.
Milo-Dino
The last time I used a xiaomi China rom and sideloaded Google store, the battery life suffered quite badly. Not sure is it the firmware or just the phone issue.
This was 6 years ago lol
speedknight
Moderator
Moderator
I using 12S ultra.
1)Play store just need to side load once, and its certified just not preloaded
2)Update like any other phones
3) Yes there's English interface
4) To prevent late, slow notifications need to manually turn off battery saving features and toggle notification settings for individual apps(All China roms, are like that not just MIUI)
animeonegai
If you value not getting location surveys from google reward, then dont get china phones. Everything else, its ok. So what if Xjp listen to ur conversation.. are you even worth his time? :s22:
China rom phones can disable or uninstall the apps albeit need guide. But using samsung s9 plus, all the bloated apps cannot be uninstalled.
ramtam1
Does anyone know if we buy the 13Pro from China now will it support Singapore 5G networks?
salmonella
The ones I've seen are for China netcom. Guess you might see if netcom supports the same 5g bands?
