Xiaomi Box Android TV Box
m0j0_vin
Actually, I bought one. And TVapp is not able to run. Also, not all channels are working.
how much are they selling it for at the show? does it come with pre installed apps?
no such thing as miboxpro.
local xiaomi doesn't sell tv box.
never buy tv box from exhibition - for mibox, cheaper to buy from lazada or rakuten.
the latest version is indeed called pro on this site - http://xiaomi-mi.com/tv-box/xiaomi-mi-box-4k-1gb/
toe_toe7
139
Yes..they will install for u..
TVApp doesn't work..i have seen another one where TVapp worked in previous show..too bad..i didn't buy at that time..
Audiology93
Confirm no local warranty from xiaomi as they don't even bring it in to Singapore. Probably just some in-house warranty from the seller.
PM me if anyone is looking to get a mibox as I'm letting go my one with amlogic s812. Already received my shield tv.
I saw a stall selling miboxpro at IT show at Singapore Expo.. is the miboxpro the latest version or is it even original ?
I want to get it but was worried. The promoter said is original and even have warranty from local xiaomi.
What is ur view?
Franky37
Anyone know any app that I can use to watch 非诚勿扰? my parents love the show and I was wondering which app provide it?
Panerex
Noobie here.
My Tv and TV wall point are not situated next to the Openet network point where the wifi router is placed.
If I buy the xiaomi tv box, I assume I need to connect it my LED TV (non smart).
Will I encounter any issues?
Many TIA
titiju
Noobie here.
Many TIA
You will need to connect xiaomi box to the TV by HDMI cable. You can connect xiaomi box to your router via wifi. But if the distance is far, your connection might be slow and your streaming quality will suffer. Wired connection is better if you can.
Sent from LG using GAGT
livetodrive
Urgent noob help needed from bros here to attain domestic harmony.*
Impulsively bought a xiaomi android box at sitex hoping to watch epl with my boy this school holidays.*
Couldn't get to click the bottom right option of 进入光芒体育 on the screen.
Also, is there any other option to watch the games with English commentary?
Pointer to the enlightenment will be deeply appreciated.
sansanjikikut
which listing on lazada is the latest, authentic real deal? quite confused by all the negative reviews on there
kweeli
Noobie here, not sure if ask this question before but appreciated if you can give you input.
I'm considering to get xiaomi tv box during 12:12 sale from xiaomi taobao store, can this box plug and play or i need to do some IP setting before can use?
Thanks in advance...
Audiology93
Depends on what app u using. Some app requires VPN. Some don't.
Sent from OnePlus 2 using GAGT
spec07
Hi guys,
Any idea if the Mi Box app "video player" could be downloaded from any site or play store into any android box? I like this because it some how able to access my NAS files and allow me to play the movies from the NAS on my Mi Box. Therefore I would like to install this app into my another android box (Minix).
Please advice. Thank you.
gregory_choo
Hi guys,
Install ES explorer on your minix. You can use it to browse your NAS and play video.
spec07
Thanks! Do I need to do any configuration for the ES Explorer? Or does it just simply install and its able to access?
spec07
Could I also check if the Mi Box Gen 3 can only support up to 64GB micro sd card? Does the card need to be any particular format? FAT32 or NTFS?
PA3131T
From the way u asked... I suggest u better avoid Xiaomi Box...
bo liao
Help guys, my xiaomi say " no memory or insufficent space" thus cannot watch movie from popcorn, how ah?
Tried cleaning it, also delete some apps which i dun use..:s11::s11::s11:
anyone?
Thank in advance.
silentscope
Its been awhile since i last used my xiaomi..
Can i check with you all, where to source 花千骨 on my Xiaomi, cant seems to find any source through many apps.
It's geoblocked i guess, any ways to get pass it?
