Xiaomi Box Android TV Box
Sherra
i'm also keen in getting this device for world cup.
so to clarify,
I will need the jailbreak version + cloudtv?
titiju
Nope. How do I install the launcher?
Follow post #247. You will need Windows PC and Snappea to install that launcher. After installing the launcher, click home button and it will present the two launchers. Choose the one on the left and click twice to activate it.
titiju
Best as cctv5+lags due to too many user and i am using cloud tv seem good. Buy the 1 month trial for 4.99usd in case u have doubts
Which app do you use to watch CCTV 5 if not from cloud tv.
whoooo
I am also seeing $8 option only. Can someone advise?
it's 4.99 usd or 8 usd? I can only see the $8 usd option ...
Chinese option have more Channels and under it it says USD$4.99 I dont have my phone with me as I did take photo of it to share with kakis on the TaoBao thread. later lunch time i upload so that GPGT
edited add pic
[/IMG]
Himedia did bundle Imango which includes live TV, else dl HDPan , VST or MoreTV. these did can install on MiBox
edit: I recd alot of PM asking me if got lag or not. IPTV like its name is very much depend on internet and subscriber speed. traffic light does throttle speed and do take note. I am using MR 100mpbs for me I got lag now n den
Search for Gregory choo post as he did post togic plus file to watch astro/starsport free
plshelp
Just take a photo with your phone and post here?
If you bought it from qoo10, you should be able to get support from them.
Hi.
I think cannot like this post picture leh..
I have email them already. Waiting for their reply.. btw i bought it from the deal seller in qoo10
Meanwhile does anybody experience this?
-While using the remote (pressing left, right and back button).
-Suddenly the app icon changed to other app icon. And I can't find the previous app in the menu.
-some of the app is gone too.
jase07
I'm using xiaomi box 1. last night tried to install vst on it. Installed snapea on windows and then connect box using usb. my snapea cannot seem to identify the box. it recognise it as android device. cannot install app at all.
any advice?
whoooo
any advice?
the mibox should also run the snappea, once it run , run the snappea on your PC it shld detects
gregory_choo
any advice?
easier to buy an OTG cable, then use thumbdrive to plug into mibox via the OTG cable.
jase07
any OTG cable will do? or need special one for mibox?
u mean i put snappea apk on thumb then connect to mibox to install?
jase07
U install snappea on ur desktop and once connect to mibox it will auto push to install snappea client on the mibox
thats what i did last night. i installed snappea on my desktop then connect to mibox. it detect mibox as android device and just kept reading data. tried to install vst apk but keep saying cannot connect.
Dimitric
edited add pic
[/IMG]
that's odd, same app but diff packages?
medscy
Hello,
Can I find out what is the launcher u guys r u using on ur mibox? I bought a jailbroken version and it comes with 兔子桌面,泰捷. I fimd the former sux though it supports English... did anyone skin your launcher? Maybe can post the pic of your 'homescreen'?
dredd
edited add pic
[/IMG]
hi..does this app allow multiple login from different devices? :D
