Xiaomi Mi 10T | Mi 10T Pro
ZhuTou!
Its like when i try to focus on something the edge gets blurry or the pictures turns out like a bad painting. Unfortunately hardwarezone I can't upload pics.
It is common to have some blur effect on the edges, this is call bokeh effect
Using auto mode will see it sometime depending on what u focus on
If u wan full clear pic, i think u have to choose portrait mode or something
Cant rmb much, long time no play camera alr
joesph
barnabaskoh
hi, i am abit confuse with the lineup.. can anyone share if the mi 10t are the upgrade version of mi 10? so is like next year mi 11t will be an upgrade of mi 11?
ZhuTou!
Usually is upgraded version but dun look at model number, look at specs instead
U look at model number will confuse
Mi is flagship model, redmi is mid range model
Like i said before, look at what u need, mainly choose between processor or camera
Xiaomi model usually is good processor with lousier cam or mid range processor with good cam
If u wan everything, just buy the most expensive Mi model
Current is mi 11 ultra cn set, global set will be mi 11
If budget is a concern, choose between processor or camera
Go gsmarena to compare the specs between diff models
barnabaskoh
Thanks! I have alrdy bought mi10t as I feel it seems rather worth it for the price point and mi 11 advantages over mi 10t wasn't what I needed.
iygnaug
Suspended
I must say, after having used this phone for the past year, it is still an amazing phone for the value. Everything is fast and the screen looks great, battery life is amazing too.
Reavl
i considering between Mi 10T pro vs Mi 11T Pro, any advice as i hear SD888 run very hot
joesph
swell phone. 33W charging still fast. tomorrow night 20:00 got Singapore event, I see on Facebook. my case just come. Shopee. S$1+ only free shipping from china
Read HWZ Forum Rules!
iygnaug
Suspended
In tech, I always believe to go for the newer one if you are going to use it for a longer duration. The camera on the 10T pro are not fantastic. If you are concern with good photos, go for 11T pro. The new processor should be able to generate better photos. Megapixels don't mean much when it comes to phone photography.
gibson7
anyone has issues with gpay? during payment or transport? mine have been having issues. whereas my wife's set seem to be working fine.
