Xiaomi Mi 10T | Mi 10T Pro
Jurong640
I can't tell the difference really.
but this is very subjective, best too see the display in the flesh. but I'm definitely liking the screen.
Sent from Xiaomi M2007J3SG using GAGT
Thanks. Shall go and try out the device myself and compare with my Mi 10 Pro.
My mi 10 pro 5G currently able to detect 5G but unable to utilise 5G as it's currently not supported.
Fizzical
I see there's an option, but also depends on carrier also?
Yes thats the setting. Are you getting VOLTE when you call out? What is your telco currently? Hope it is supported by Starhub.
otaku7
I'm using giga. don't think there volte support yet
kkfa2018
Not supported? Is it due to plan with telco? I thought auto free trial? Must buy 5 G plan? Appreciate advice. If must buy 5G plan I hold back on these phones for now. Thanks.
Q10spy
Currently xiaomi 5g handphones are not supported by local telco. If you want 5g support you have to get the big nanes like samxxxx, iphoxx
chris1987
Anyone knows which type of charger spec should I look for? Looking to get one spare to put in office.
Many thanks!
kkfa2018
Oic Thanks. In that case my current phone stays with me for another year.
kkfa2018
If not supported by telcos here, why buy xiaomi 5G phones? Apart from wanting new toy of coz. Just curious.
Ributto
I'm pretty sure the Mi 10T & Mi 10T Pro 5G is supported by Singtel, Starhub and M1. They have 5G contract plans for both Mi 10T & Mi 10T Pro. Starhub advertising it as one of the "Most affordable 5G phones yet".
dodongdodong
Just chatted with m1. For the meantime M1 supports 5g on these BIG brands. Could be same for other telcos.
Samsung Galaxy
Note20 5G
Note20 Ultra 5G
Z Fold2 5G
S20 FE 5G
Huawei
P40 Pro 5G
Apple
iPhone 12
iPhone 12 Pro
iPhone 12 Mini
iPhone 12 Pro Max
Q10spy
Samsung Galaxy
Note20 5G
Note20 Ultra 5G
Z Fold2 5G
S20 FE 5G
Huawei
P40 Pro 5G
Apple
iPhone 12
iPhone 12 Pro
iPhone 12 Mini
iPhone 12 Pro Max
Just found out, Starhub slightly different for adding support on oppo find x2pro realmex50pro, and mi10t/tpro
yh_lee
May I ask about the warranty? I see some sellers stated 12 months and some stated 2 years. Thanks
local set
599 and 699
can use with couples too
shopee
Sent from Xiaomi POCO F2 PRO using GAGT
