Xiaomi Mi Max
Nakedtoes
Finally just unboxed my Mi Max! :s22:
It is huge indeed compared to my RN3 side by side! :eek:
However, it's so so so freaking slim and that makes holding the Mi Max is not a huge problem in one hand! :)
Such a beautifully designed phone and awesome awesome screen indeed! :)
All big screen lovers must buy it since the price is so "economical"! Don't regret it if you don't Click to Buy and Add to Cart now! :s22:
Now yr time to poison others?
kelvinti
meaning got google playstore?
Yes!
Coz it's considered as an International handset preloaded with official Global ROM and as well as preloaded all the required Google Apps as per the official Android OS guidelines even it is only available in India, unlikes Chinese Export set which there isn't any Google Apps and PlayStore being installed at all but with all their very own Chinese sites Apps and Chinese online stores!! :)
So, quick quick click to buy now! :s8:
kelvinti
Don't worry folks!
As long as it is an Indiana John Export set! It's on official Global ROM preloaded with all the required and standard Apps likes on Samsung, LG and Sony phone models!
So, don't ding dong ding dong! Click and buy now before the offer price is gone again! :s22:
Look at the price! How tempting it is man for such awesome phone!
Left Click, Right Click, double Click now...! ;):s22:
kindlesingapore
Yes!
Thats great to hear. One question, can I use a tablet 4g data only sim on sim1 for data and another sim on 2 for calls?
If that is possible it's time to "throw" my ipad out the window :s12:
kelvinti
Can!
SIM1 and SIM2 can be configured individually for Voice and Data or Voice only or Data only!
For example:
SIM1 for Voice call/Data SIM.
SIM2 for Data SIM only!
However,
If SIM1 is on 4G Data SIM, then the other SIM2 will only have 3G connection!
Either SIM, only 1 SIM has 4G connection at any one time! The other SIM will be downgraded to just 3G!
As for to "throw" your iPad to me or not! I cannot comment bah! :s13:
amazingone
wah looks good
Sent from Sumire using GAGT
kelvinti
Okay! Flashing Sexpert.....!
I need to double check the flashing steps;
1. I will use "Minimal ADB and Fastboot: cmd to enter EDL Mode.
2. Then, use XiaoMiFlash.exe to flash to MIUI8 Global Developer 6.7.29 ROM for Mi Max, right?
That simple and straightforward, right? :s8:
kelvinti
When I got I wonder why box is in English.. Then I go search India set pic.. Then know is India set.
7.5.3.0..then OTA to 7.5.6.0
Haha!
Blur blur but so lucky to get the Indian set, bro and that started the ball rolling! :)
Must thank you! :s22:
Just Me
Isn't there a global beta miui 8 for mi max? What's the advantage of the developer rom?
Sent from Jiak Liow Bi phone using GAGT
