Xiaomi Mi Max
canonrow
I saw in a youtube review that mi-max can be bent easily along the long edge & it'll open up a "mouth" 😯
Have anyone seen that during actual use?
DRAGONGUY
That one is brute force...... actual usage no one will use that kind of force..... unless u are always angry like hawk.....
anirudhks
kandinsky
u using it now?
got gaps on both sides?
newton effect?
Very slight gap but if you get white it looks quite seamless as part of the bezel as white on white.
Newton effect - First day didn't notice any, after 2nd day, noticed some slight effect but only at certain angles.
I think the angle of the light hitting the screen, and the angle we are viewing the screen, and the depth of the air gap between the glass and the display, must all zhun zhun be 'correct' then you will see the newton effect, at least that's how it feels for me.
Sometimes I can try to find it but not matter how, won't see it at all. So quite a mild and temporary effect. Not a bother for me.
In the feedback, they mentioned there's a 1mm gap. Is it bad? Btw are these hard to apply? Its quite cheap (USD1. 80), shld I get like, 5, to be safe? :)
I saw the reviews too, that's why I opted to get white, so if there's any gap, can't see it. If you get black, I think small gap also will look obvious?
charleslee
Oh.. Thanks for letting us know. I want the pink one (rose gold), but if there's gap at the sides, it'll be kinda ugly unless I can find a phone cover that will overlay onto the gaps..
Currently I hv a transparent one applied, that does not cover the sides too. Think I'll stick with this till the China plants make slightly bigger ones ;)
kenner
Anyone know if I can get this at singtel or m1 without contract?
Sent from Samsung SM-G935F using GAGT
Oinkize
