Xiaomi Mi Max
jameshong
Ahh! New Mi Max folks,
Don't forget that one can Double Tap to wake screen in MIUI8 just likes those LG phones. :s22:
There is an option to enable it in Settings. By default, it is turned off.:)
Got double tap to sleep just like LG bo?
gerald27
isn't faster to use your finger to unlock the phone?
After you dbl tap, still need to enter password
kandinsky
Think the application is probably more for like when you have the phone flat down on table (e.g. working or during a meeting) and just wanna quickly check the time or for notifications? If want to use the phone, yeah, finger unlocking will be faster.
For me, I happen to also use a miband that can be set to unlock the phone within a certain proximity. So if I swipe up after double tapping it also unlocks.
knight123
just a quick question. May i know is there any different between export set and buy it locally from china?
kandinsky
Export set - Someone bought from china/india to sell here. What's the diff?
At most, china set bought here has the convenience of the shop helping you flash it to global rom, so you can use it outta the box. But if you don't care about that, you buy in india/china yourself should be identical. Only that china set has china rom, india set has global rom.
kelvinti
Finally, gotten my Mi Max a SP after 3 weeks. :)
No white spot and no rainbow.. Sits nicely. Gold front panel.
The brand is Mocolo. It costs less than S$9.00 from Aliexpress.
best_ctzn
My Mi Max has been slow in receiving messages on Whatsapp and Telegram. Sometime need to open the app then the messages will come in one shot though time stamps are few hours ago. I have tried to tweak the setting to remove any restriction but still persist.
Anybody can help? Many TIA.
kelvinti
China or global rom?
Oinkize
Why your table always wet 1?
Can wipe it dry? :p
hachi
I also got the same problems.
Nakedtoes
no problem for mine set... very funny ow come so many ppl experience slow in whats app
Oinkize
I think can try to exclude those apps from battery optimizing and allow auto starts.
