Xiaomi Mi Max
ipaq4444
Confirmed and chopped! No issue with any sensors with this brand of SP! :s13:
I, myself have been using it (Gold color one) for almost 2 weeks already! :)
No regret!
That's why I highly recommend this Mocolo SP in the thread even though it's on the expensive side about USD$7 per piece! :s22:
will finger print magnet?
hachi
Really poison, I feel like getting another silver 32GB one.
Phen8210
so for 5v max is 1A?
And another thing, dont know why my app still can run when i locked my phone, the sound from game still playing
upgrade to miui 8 seem to increase resource usage and reduce battery life, maybe is placebo effect.
Plastick
just joined the mi max club. recv mine earlier this evening. now flashing to beta rom 6.9.15 :p
just now was doing some app downloading on wifi freaking slow on the pre-loaded global stable rom, very slow! is it the wifi issue which was fixed in the later update?
Plastick
izt normal to recv an india set with all the warning stickers? ("do not disassemble battery w/o specialized tools", "protect consumer rights, pls keep this label intact", the IMEI / SN
thank you
Phen8210
i have that too, but the imei fade off cos i use alcohol swab to clean my phone hais..
kandinsky
China set had these:
Not my pic.
I just took out and stuck it on the box.
jazzman80
probably I stick to 7.3.14 for louder volume. I think that's the last firmware before they tuned down the volume in later versions.
touchme
Wah, replacement parts already out at mainstream prices.
But dunno how chiong, good or reliable.
From my xp, screen+ digitizer still ok, but never batteries.
Mclairs83
i worry more on panels. usually they use low grade panels. the original and the replacement part look alot different. :(
kelvinti
Very poisonous thread..
Think Positive! :s22:
It's not a poisonous thread but a super antibiotic thread! :s8:
At that price for such specification, just "Click to Buy Now", bro! ;)
Don't ding dong ding dong likes an ah girl! Be an ah lian....makes fast and furios decision to buy now! :s13:
Plastick
need to find a cover/casing now just in case i drop this big screen device. the build doesnt look strong
azbyza
Thanks for finding this.
I always worry that China phones will use low quality parts especially the batteries which are not easy to check. My Note 3 battery only lasted 3 years and so I was looking for a phone that has removable battery so that I can buy spare removable battery to replace them easily.
I actually consider that phone batteries are consumables just that they last about 2 years to use up. Almost everybody knows that. There seems to be a silent conspiracy in the phone industry to make phone batteries non-removable so that most people will be tricked into buy new phones every 2 years when the weak batteries caused problems. That's why the Telcos also offer 2 years phone upgrade contracts to catch consumers at the right moment.
I expected China phones batteries to last less than 2 years so now I'm quite relieved that I can buy Mi Max battery. It will cost a little more to open up the phone and replace the battery but I saw on the YouTube that Mi Max is quite easy to open up.
