Xiaomi Mi Max
Oinkize
wah that bad ah at home can't receive 4g is jia lat lehhhh
anyone else got that problem? will the phone sold by challenger have the same issues?
Depending on network and location.
Mine almost 4g everywhere i go...
Compact7
Both mine tested in Msia on Celcom, Miui 8 and Miui 7, both 4G data ok and consume less battery than 3G.
KalTorak
MIUI8 6.10.27 Weekly beta update for 3/32GB just out today.
cscs3
Then what normally happens for you?
You have to wait extended period of time for weak or no signal before the phone switch to another network. Tested a few time, it can takes as long as 2 min.
Oinkize
This is not normal.
You may wish to factory reset your phone or check with your operator.
Nakedtoes
What type of screen protector yours guy using? It seem the curved edge always can't stick..
Can search the thread.. Got few dollar one to more expensive one.. I also got recommend before.. Search my posts
ipaq4444
After my first Max updated to Miui 8, my wife disappointed by some very sweet and cute of miui 7 themes no longer compatible. That's why another will be stay put on miui 7.
Was wondering if I got a defective sensor. So I just tried my first ever fingerprint setup, lucky fingerprint scan and unlock function still work very fast and smoothly. Sensor should be good. What I think now is it could be the factory 7.5.3.0 rom do not enable that touch-to-fingerpad-awake-phone function.
I also forgot if I discovered this before or after miui 8 update. :p
did anyone revert back to miui7? Do you find miui 7 faster compared to 8
1982-1994
me. all along I'm on 7. reason being, apps cannot be disabled on 8,hence the downgrade.
volume is loud on 7.
i find that it is sufficient for my simple needs.
Compact7
I just done it last night. I back to 7.5.7.0 with quick ball function. I still very new to miui so not much experience. I notice 7 used less ram, more theme to choose from. It also occupied less memory.
7 don't enable touch fingerpad to wake phone which I miss this function. The quickball on lock screen plus double tap wake phone is really usefull.
Another thing I noticed is miui7 got more sub selections than 8.
Still experiencing.
sumkong
Lately my max has problem receiving WhatsApp. The messages only came thru after or when I open the phone or WhatsApp. It was not like this before. I have been using Miui 8 beta all the while.
