Xiaomi Mi Max
cscs3
They only look at their own authorized retailers, which are Challenger, telcos, Mi Store on Lazada and Mi Home Store at Suntec.
If you get it from third-party, despite being a local set, you aren't eligible for the loyalty promo.
Sent from Sumire using GAGT
No regrets as free gift is like about $30. Saving is still great from non agent set.
1982-1994
Now in msia :)
Ya. Miui 8 vol is at low side. My wife did comments the whatsapp msg alert was low.
Lot of works need to be done at xiaomi side.
if you don't need the features on MIUI 8,why not try out 7.3.14?
radiancez567
Collected my Xiaomi 5000mAh and Xiaomi Selfie Stick today. The store was so crowded with many others also collecting the free gift. Have to provide hard copy of the receipt.
chobits
I noticed some noise whenever I plug in my earphones and switch to a new application. Like there is a fan in the phone turning at very low noise level. Anyone hear it too?
Even when I clicked post reply in this app or tap on the quote Button, I hear it..
jace88
Any good? I was thinking of going over after lunchtime. Can the selfie stick even fit the Mi Max?
jace88
For Xiaomei Mi Max, what type of screen protector and case that you use, where to buy?
I use a tempered glass from Hitec. Keep in mind the face is actually slightly curved so you can either get the tempered glass which stops just before the black border around the screen o the one which continues until the edge but has a slight bubble on the left/right side of the screen (i.e. the bits which are curved).
For the case you'll probably need to buy online since not much in stock at shops other than the usual Goospery cases which range from $10-$20 depending on whether you buy from markets, SLS, pop up stores/kiosks or normal shops.
I personally alternate between a $15 Nilkin Frosted Shield case I bought online (highly recommended in terms of quality and strength since it brings some rigidity, is slim and textured, and also comes with free plastic screen protector) and a red $5 TPC one I ordered from Aliexpress (same bright red as Apple's official iPhone Product Red colour). Prices are approximate guesstimates from recollection.
Also consider getting an iRing. You may think you can handle the phone but the iRing makes it alot easier and also can stand up to watch on...
Compact7
if i buy mi max export i can also update software?
only $244 for export set 32gb... not bad i think 6months store warranty
http://list.qoo10.sg/item/XIAOMI-MO...E-PHONE-TABLET-6-4INCH-DISPLAY-16MP/439633566
If u get an india set mostly can ota to global rom itself.
Otherwise can selfflash to global rom. Quite easy de. I first time xm user did do it myself even though mine are local set. I from miui 7 to 8 then to 7 then now back to 8 lol. Here got lot of tips shared by bro here. I able to do it also thks to bro whoiam helped me.
244 very good price with 6 mths warranty. But if u look closely, u can get local brand new set from seller who recontract with telco but dun want the phone. Price is within 250 to 300 range 1 yr xm warranty. Ask for receipt for warranty claim just in case.
Compact7
Can share us link? :s12:
