Xiaomi Mi Note
miltonwkw
Icic, no idea if it's only Miui 7 or what cause I updated the moment I opened the box. :)
Will try to reinstall Whatsapp try. Thanks for your help!!
Hi Bro, have u solved the problem? are u on greenify? I solved my whatsapp connection issue by uninstalling it.
5408854088
how do we remove icons on the home screen? it seems that some cannot be removed and some when dragged to the trash bin means uninstalling them. anyway to go about it? thanks!
ApPle5
Nope, issue still not solved after I uninstalled and reinstalled. Not on greenify, does that help? Think will give it a try. Quite pek chek no notifications :mad:
ApPle5
All apps installed will be shown on the screen unless you use another launcher. Can try Nova launcher.
5408854088
thanks. anyone has any idea how come the phone is like using ram of 1.5gb when the phone is doing nothing with background apps all cleared? is that alot? possible to control it?
5408854088
after updating to miui 7 the ram usage seems better but could hardly get 2gb of free ram. anyone know how to disable background data with exception of some applications?
5408854088
another thing, how to set the video quality as 4K by default? it keeps going back to HD after i exit the application.
hwaa
im new to xiaomi phone.
just to ask gurus here... is the Mi NOTE range better or the redmi note series range better?
cos now got promo for redmi note 2.. but seems like for buying without contract prices, Mi note commands higher price.
RaptureM3
mi note > redmi note
look at the price/specs. quite obvious
minotepro
Dear bros
I am new here but have been reading this thread......... just got a note pro and have been flashed MIUI 16.5.4.0 (LXHCNCD) by the shop and I need some advise from bros here......
I have browse thro the entire 71 pgs to find out the latest version of MIUI 7 for Note pro link (global stable) ... I would appreciate if some bros can help me where can I get the latest V7 for pro (global stable) ....
from the official website, I can only find V7.0.5.0 LXHCNCL (China Stable)
Thank you all very much....
Cheers
s1mple
Dear bros
There is no MIUI v7 global stable rom for Mi Note Pro since xiaomi doesn't sell the phone outside china. Only Normal Mi Note has.
minotepro
Thanks bro for the reply.
Can I use NOTE MIUI v7 global stable rom for Mi Note Pro then?
Have anyone use it on Pro?
Iced-T
Does this phone need a cover for protection? will the aluminium bezel get scratched easily? how about the rear and front gorilla glass?
osirisx
Do you guys remove the frosted sticker at the back?
It's covering the flash module, but the imei and phone details are on the sticker
