Xiaomi Redmi Note 2
tanchoo1
Thank you for your reply. Can you help me to confirm if the music player is shown when you pull down the notification bar?
7.3.1.0 somehow removed it...
Yes you are right. I don't see the music player when I pull down the notification bar in 7.3.3.0 either.
Also in Explorer app, the FTP server has changed. It is no longer at the bottom of the app, but in the "Categories" window near the bottom of the window.
Oinkize
Thanks for the confirmation.
Updating now...
Oinkize
Got a shock. Phone stuck at a point while the loading bar at 3/4 progress. Luckily it managed to boot up properly...
tanchoo1
So the update succeeded, I guess?
It is updating from a 1GB file, so it will naturally take some time. About 20 minutes for me.
tanchoo1
So fast got new updates again?
I don't create the updates, I merely report them. :)
Release Notes for 7.5.1 Global Stable ROM for Redmi Note 2:
Backup
Optimization - Mi Mover transfer speed (05-09)
Weather
New - New white design (04-27)
Mi Account
Optimization - Simplified sign-in process and creating Mi Account (04-19)
Cleaner
New - New design for Cleaner (04-27)
Optimization - Accessibility support (05-24)
Fix - FC issues (05-24)
Security
New - Fingerprint support for App lock in Redmi 3 Pro (04-27)
New - Added on/off switch for App lock (05-03)
New - Customized settings for App lock (05-03)
Mi Cloud
New - Added "Back up now" feature for fast backups (05-19)
luei74
Updated to V7.5.1.0 (LHMMIDE), still monitoring if there's any battery drain and other issues...
Oinkize
Backup
Weather
Mi Account
Cleaner
Security
Mi Cloud
I am not complaining but just suprised at the frequency of the updates. The previous update gives me very good battery life...
kazuki666
I am now using the claimed original battery bought from taobao for my Redmi Note 2 now, since Mi Singapore has been quite reluctant to reply my enquiry to buy a battery from them. The "original" battery is ok, but I noticed the battery life seems to dropping faster than the real original battery that came with the phone.
Sent from Xiaomi REDMI NOTE 2 using GAGT
amazingone
Backup
Weather
Mi Account
Cleaner
Security
Mi Cloud
MIUI 7.5 integrates sone features from MIUI 8, a good update IMO.
Sent from my Rice phone using GAGT
Oinkize
@tanchoo1 may i know where did you manage to get such fast information for rom updates?
tanchoo1
I would say:
* 50% chance it is a fake. China is very good at making fakes.
* 25% chance that it is real, but second-hand. In which case, the battery draining issue is a typical symptom of an old battery.
* 25% chance that it is real and brand new. Then you need to charge it full overnight for several days so that the battery can calibrate itself and give you more accurate readings.
