Xiaomi Redmi Note 3
cowheadog
My friend's china set has the tray on the right. Does it mean the SG sets hav the other tray?
amazingone
.笨 小 孩.;100711542 said:
Wah swee! Thanks much.
Any other "hack" this phone can do?
There's this Reading mode that you can enable it for better reading eg. it will turn your screen slightly yellowish. It's similar to Apple's Time Shift mode on iOS 9.3, except it has been there long ago.
Sent from my Rice phone using GAGT
Norman Chan
Remember to check the spec, for the non pro version which is using Mediatek CPU it cannot support micro sd card,only the pro version using 650 CPU support micro sd card.
.笨 小 孩.
Yup, tried it last night but I find it too yellowish. Didn't like it.
What's the shortcut key to activate camera ah?
guards80
Status Date Latest Status
- 09-04-2016 With Delivery Courier
hope today can get.....
amazingone
Looks like many people complaining how Xiaomi implements this sticker labelling technique..
I think what Xiaomi should do is follow what they've been doing on their China sets, which is attaching all the regulatory labels on a plastic sheet, which users can remove it easily and also store it well too. ↓
.笨 小 孩.
Wasted some good old whiskey to rub away the sticker residue last nite. The back is now all good and smooth. It would be better if it can be peel off cleanly in the first place.
Totally loving it in comparison to my Sony z2. Now, if only this phone is also waterproof, I think it sales will skyrocket.
Anybody got problem with uninstalling app? I click uninstall it straight reboot for any apps wtf :eek:
No issue for me. I deleted some of the pre-installed app and was surprised I can even delete the default browser.
chong
Played with it since late morning... Here's my take:
Pros:
Phone is smooth and responsive!
Generally good build and feels solid in the hand
Fingerprint sensor unlocks while phone is off, and it's pretty fast too
Buttons have good clicky feel
24.5GB free space after initial app updates
Minimal third party bloatware that can be uninstalled
Cons:
Speaker does not sound good
LCD is dim, yellowish by default, and slightly uneven in tone.
Metal edges at the back are slightly uneven
Rear Sticker leaves residue but can be taken off purely with 3M scotch tape
MIUI 7 has improved but still remains an abomination :D
Overall, it's an overachieving budget device that's well worth its $300 asking price!
