Xiaomi Redmi Note 3
Nakedtoes
Hi,
I updated to 7.2.3 and experienced the following:
1. The phone was very warm and within half a day battery dropped from 100% down to 80% without using it only in standby mode.
2. Second sim not working properly. sometimes no signal and keep on searching connect and disconnect.
3. Touch screen was not responsive took about 30 sec to react.
4. Wifi was very very SLOW and most of the time couldn't be connected.
My solution:
Went to service center and requested the staff to downgrade to 7.1.8. Once done, connect to WIFI and update to 7.2.3. During this process, did not install any apps from playstore. Once 7.2.3 was updated, I did a reset and my phone started a fresh and all my problems solved.
Hope it helps.
why downgrade to 7.1.8 then go back 7.2.3 again? btw u ask service center to downgrade rom will yr data and apps all gone? how long it took?
Nakedtoes
so far 7.2.3.0 i only experience sometime finger print sensor not working... so far very happy with the phone... nv experience lag at all.... any some pics with the case and tempered glass i got from QOO..
Nakedtoes
Hi,
My solution:
Hope it helps.
everytime update firmware need to reset phone and redo and reinstall all the apps and setting where got time? does the xiaomi backup really works? previously i use they only back up partially only
batniss
I'm on 7.2.3 wireless range was not optimal but no issues selecting either 2.4 or 5 as long in range. So far the only device that could not connect at my usual location to the router among all of the other mobiles I've been using including their redmi 1.
batniss
Finger print not working?
Maybe fingerprint also on standby?
Usually the case I just press power on button once then finger print, it will work
So I believe it's on standby but no idea how to make it not on standby.
makav31i
Wah...like everyone is using the ipakky case...
batniss
how much is it and where to get (the casing)? sorry if i missed the earlier post on it.
thank you.
garychengjw
Im using resurrection remix...
Sent from Xiaomi REDMI NOTE 3 using GAGT
Cool. Mind sharing source to download/instructions?
Sent from Samsung SM-G935F using GAGT
halocast
those on old 3g plan..
if yr connection like quite bad.. switch the preferred network to 3G only.
after i did that. the connection became better :p
otherwise it was dropping every few mins
Nakedtoes
I switch to 3g also.. Not much different compare to 4g. And save more battery power.
Nakedtoes
Feel a pity some great phones like sharp 402sh came out too early. If came out now can use sd 650 or sd 820..best in looks and powerful enough.
So far what I loves abt this note 3 is battery life.. Heavy usage can last 2 days. Finger print sensor and the metal build. And absolutely no lag at all. Really wonder how can xiaomi sell so cheap.
amazingone
Want to sell> F-code for Redmi Note 3 Snapdragon (for MI SG site).
Can buy before flash sale start. Anyone interested?
Eh if you are selling it for monetary value, please don't. I believe the F-code is given to you free and it's a privilege for you to get it in advance, also no sales allowed here too.
If you don't need the F-code just kindly post here and if one needs it then give it to her freewill. :)
Sent from my Rice phone using GAGT
