Xiaomi Redmi Note 3
DigDub
the hardware inside the phone is good.. f2 lens somemore... so many believe is the software limitation of the stock camera...thus many using third party one... for me i find stock one not bad
interestingly, the china non sd card helios x10 version camera I believe is f2.2, while the global qualcomm version is f2.
Nakedtoes
Yes.. So this snapdragon version is really good.. Hope they dun play same stun after mi max out... Come out mi max 2 or mi max pro with snapdragon 820 or even 652..snapdragon 652 is better then 650.
ZhuTou!
The rooting process seems complicated as compare to old days
From what i read need to flash old rom to unlock bootloader then able to root
Sian man
ZhuTou!
Wooo lai liao :o
seph
7.2.5.0 is availabke via OTA now... :)
I'm downloading it now... :)
Hi, kelvinti. Are you able to connect to 4G network after update to 7.2.5.0? I cannot get 4G after I flashed to china developer rom. Thinking of flashing back to global stable.
ZhuTou!
mine is the high accuracy gps leh
all my previous lousy phone can track well
I guess only lor
After using this phone i noticed its not user friendly compare to other brands
The permission/battery option need to configure urself to make apps work as per normal
Its a good option but not good for common user
mun
Mine is China ROM 7.2.5.0 and have 4G network, but my rmn3 is MTK X10 (not SD version).
You may want to check if 4G is enable on your SIM 1/2 in the settings
infocus
i have flashed to 7.2.5.0 and able to get 4g on m1 network. works also when i was on 7.2.3.0.
kelvinti
Yeah!
No 4G connectivity issue here be it on the previous 7.2.3.0 or now, on 7.2.5.0 wqith StarHub. :)
My SIM1 is a StarHub 4G sim. My SIM2 has a DiGi sim. :s22:
