Xiaomi Redmi Note 3
Computeron
using default charger? :s11:
it supports 5v/2A charging.. so not sure why it shld be slow?
shld be able to hit 50% in 1 hr..
I Using its cable plugging into multi port hub.
and maybe its becuz after 95% charging will be slower... some phones are like that.
i noticed.... i using google music play to play music... after sometime it will auto quit...
any one facing this?
trying miui default music player... but no album art leh... sianz.
halocast
that's possible... trickle down to prevent dmg :s12:
JivBunny
Charging with 2A charger from 11.30am till 6pm yesterday. From 0 to 73%
Fellowes
Yup, that time I use Meizu m2 note after awhile the Google Play Music will auto end task and stop playing, I though something wrong with it. Woah, Redmi Note 3 also like that. Other phone like iPhone, S6, Note 5 don't have such issue lei, the Google play music will keep on playing until I press stop.
Why is that so?
JivBunny
My note 2 charging speed and battery drain all OK.
Note 2 battery is only 3000mah
The note 3 battery is 4000mah
But still I think the charging is a bit too slow. Cos I am using ip6 and used to getting my phone charged in less than 2 hr
halocast
iphone 6 is under 2000 mah right? :s11:
so if less than 2hrs.. this probably will take "twice" as long :s13:
Fellowes
no sd card slot. my set reckon can hit 6hrs sot.
wtf... that is slow wor. tats 7.5hrs.
tats very WRONG.......... RIGHT?
Wow! Something is wrong here. 4000mAh battery using standard 5W/2A charger take usually from 3 to 3.5hours max to full charge only.
halocast
You ship via 65daigou???
Btw, Lazada no longer display Redmi note 3 when you search it.
probably out of stock riao.
tmall xiaomi.. got sale at 12 and 8 pm later?
feel like hooting a miband and note 3 :s12:
JivBunny
Let's put it this way, very disappointing that the phone battery management and the charging is very slow here. U guys have the same phone, waiting for u all to verify my charging timing to see if it is my set having issue or is it something that everyone faced.
xiaomi shld realized that putting big batteries without quick charge is probably Not a very good move
