Xiaomi Redmi Note 3
kelvinti
its good.. i love the UI.. totally refreshing.. performance wise now testing.. as mentioned before.. my mi max gaming performance was really really good.. did not drop frames on that particular game.. so thats one of my reason why i want to flash the new rom to see if it makes a diff..
now trying to flash my mi max to a normal rom.. currently now on the sellers rom which i donno what it is.. lols..
bo bian.. i thought special edition means like some special rom ba.. didnt know its for another version of this RN3.. so many different type.. omg...
oryt... just tested the game again.. and sadly.. still have the graphics problem..
just find it weird.. same GPU mi max has a bigger screen somemore and yet can out perform RN3
sad man..
can i just ask... is it because the pixel density is higher hence maybe causing a drop in performance compared to the bigger screen on mi max having less pixel density?
Ya!
MIUI8 UI is refreshing and smoother amid some minor bugs here and there as expected in an early Beta rom.
As long as they are the same FHD display, same SD650. The screen size should not, I said should not affect the same game play! However, that needs to be further confirmed by senior sexperts here! :s22:
As what the bro suggested on the Penthouse floor above, submit a bug report to MIUI8 Team about the game issue! :)
Having said that, the MIUI8 Team may well aware of some game issues that need to be ironed out on its MIUI8 Beta ROM as time goes! :)
Ahh....! :eek: Mi Max is being mentioned also... I scare scare...! See no evil...! Gosh! :o=:p
Nakedtoes
I m using mi max and comparing to note 3 I find mi max screen is better and sharper..
Cyno505
Hi all. Between Redmi Note 3 and Mi Note. Which want is a better buy? Got an offer of $200 for Mi Note left with ard 3 months warranty.Or shd i pay more and get a new Note 3?
Tech n Travel
current gen of SD650 n SD652 are actually better than SD 800 or is it SD 801 i think..
anyway @kelvinti its just that particular game.. and i also experience the same when on the stable global rom.. it doesnt lags.. just drop frames when i use a special skill on mass mobs.. the framerates drop to like super low.. >.<
Tech n Travel
depends what u like... i feel they are quite different.. mi note is old model also.. and 2nd hand right? for me gadgets and all i prefer brand new in box sealed.. xD u dont know what happened to the phone on a different user..
unless really want that phone and no budget and cant wait then yea.. maybe ill go for 2nd hand..
JuXn5566
nope. pixel density doesn't matter if they are at same resolution. Mi max is more expensive device and there is a always reason why mi max is not called redmi max. There might be superior parts in mi max that you don't know. As for Mi max, I think is because it's bigger so heat can dispense better and less occasion of throttling will happen.
Just Me
Actually, the screen, stereo speakers, camera and overall build of the phone is better than the rn3 not to forget it's 64gb. the battery is only 3000mah but it supports qc2.0. For 200 it's a pretty good deal.
Sent from Jiak Liow Bi phone using GAGT
JuXn5566
I love my Mi Note, been using it for 1yr and 3 months. Everything about the phone is premium. But it a little bit slower compared to Redmi Note 3.
JivBunny
Have both the Mi Note and RMN3 Pro
Is the MiNote 64gb model ? For MiNote, the build is very solid, running on 3gb ram. I would say it is very good for most tasks even today. for $200 with 3 months warranty left. I say its a good deal. But you probably cannot find a lot of accessories from shops, so need to buy online.
Just Me
With 13% battery remaining
