Xiaomi Redmi Note 3
otacon
1) Spec.
2) Camera better with OP3 i think?
3) MIUI 8 has ads. Although i know that i can use root to uninstall but would prefer not to do that, as i'm not sure if i remove the apk/package will it affect the fw upgrade.
1) true. but still 4000mah takes a long time to charge.
2) OP3 has DASH charger i believe that would compensate on the "battery size".
Got ads means what? Bloatware?
skrw105
Hmmm...
On 6.8.18 now. Tried update to 8.0.1.0 but couldn't verify update package popped up.. :(
u r on beta, i think u can only update using fastboot edl.
think stable miui8 rom 8.x.x.x, only update on stable miui7.
kelvinti
Hmmm....You have got the point! :)
Passed then... I will just stay with 6.8.18..:s22:
kelvinti
Ok. Updated my gf RN3 to MIUI Beta Stable 8.0.1.0.
How come the 3 fingers swap down to take screenprint isn't working? KNN.... :(
I promised her that is a nice addition and now cannot do it... :(
joeidle1
Hi guys, just to check, if i where to buy a china set from smart cell, i'll need to flash it to global rom myself right?
JuXn5566
Everybody use their phone differently. you can leave home at 60-70% doesn't mean that everybody can.
once a while you will receive it in ur notifications.
There is a line of promoted apps at the bottom is so irritating, using up my screen space. Don't like the advertisement of apps that comes with Miui 8.
Any form of ads in MIUI can be turn off. The only notification ads I saw on global rom is from MIUI browser app, which can uninstall without rooting. Basically just use chrome.
The promoted apps can turn off by clicking on the folder name and turn off the switch.
Sent from Xiaomi MI NOTE LTE using GAGT
JuXn5566
You got set it in the Settings?
eekee
Chrome also has an ad below the browser, any way to remove? Thanks in advance
