Xiaomi Redmi Note 3
xahmeix
Hai... If only it has nfc ... I read online. An app call super beam helps transfer files n data over WiFi direct or WiFi. So its an option. Solved my prob before iI downloaded it tho..
Yup Done all settings for the major electrical stuff at home liao using ir blaster. Not enough post count. Can't use quote function
Hyperephania
Anyone playing Summoners War on RMN3?
Everyday when I enter the app it will have an error "unauthorized program detected", I clear everything but it still shows the error, only after rebooting then it works. However the next day it will have the same error.
Does anyone know what's causing this?
Shutterbox
Anyway for those with the new sets, don't upgrade to MIUI 8 if you want maximum battery life. The current best battery life for MIUI 7 is 7.3.6.0 for global Rom. 😁
I think you are right.
I updated to 8.0.2 n battery life sucks.
Anyway to update it back to global 7.3.6.0?
kelvinti
Be prepared....:s8:
Redmi Note 3 thread might be alive again as many Note 7 users might buy it while waiting out the Note 7's historical storm! :s8:
flame2000
Be prepared....:s8:
But Note7 & RN3 are completely two different products. One is high end, the other just a mid range phone.
Maybe Note7 users will go for Mi5s Plus or Pixel XL.
Oinkize
Maybe buy to use temporary till note 7 is cleared?
