NicoNicoNii
- Nov 10, 2014
Can post photo of it?Got one spare smoked transparent case. If want self collect at marsiling MRT.![]()
will get direct from xiaomi, is it difficult to install myself? thanks
This one original from xiaomi. Really damn thin got paste like no pasteAiya, same as those rmb6-7 de. no need get so good de![]()
Yeah for me i use google installerHow you all side load Google playstore ah? Use the Google installer?
Sent from Xiaomi REDMI NOTE 3 using GAGT
Seems like Google installer did not install Google services as a system app. Had some problem with push notifications
You can try root .. And use lucky patcher to install google service as sytem allSeems like Google installer did not install Google services as a system app. Had some problem with push notifications
Sane as mine but managed to update after edit the build.propmy redmi note 3 is running miui 7.00.11.00.
I tried to install the miui official china rom Version: V7.0.19.0.LHNCNCJ (MIUI7), I tried wipe cache and renamed to update.zip but it failed.
how can I flash to the official china rom?
