Xiaomi Redmi Note 3
zzxxzzxx
Hi all,
got a SD650 version from tmall reseller, tried and could not receive SMS(can send though), any idea what may be issue or how it can be resolved?
Have tried the 3G sim card on both sim slot 1 and 2.
Any advice is much appreciated.
Thanks in advance,
wow. how much was the damage?
thswei
reply
Hv u tried what's app? Not 100% delay. Just sometimes.
I think the solution is found. seems to be due to i-message not be able to be send to android. After i-message turn off, the stock and 3rd party messaging app is receiving the sms.
thswei
reseller price was RMB 1506(ard SGD335). plus sensitive air and agent fee, ard 370, package was above 500g. since xiaomi bringing into Singapore, might as well wait.. bought 1 week too early..
cscs3
bro. can advise how to disable?
and talking about this, i need to enable playstore to access to mobile data. i cant download using data now. haha!
Try the 3 vertical ... at right top of Xiaomi Market. Setting, turn off update, auto download.
I am on Mi4i global version, but install Xiaomi Market just to keep other Miui utility updated.
cscs3
红米note 3 全网通 supports CDMA bands, which would mean it support 移动4G, 联通4G and 电信4G.
电信 uses CDMA for its 3G network, and the Helio X10 doesn't support CDMA.
Go google for more details, it's all around the web..
Sent from my Rice phone using GAGT
But Xiaomi website seem indicate Hello x10 note 3 support 联通 3G CDMA.
What is the different between 联通 3G cdma and 电信 3G cdma? I am confuse.
I think Singapore 3G should be 联通 3G cdma ?
Wessleh
Anyone wishing to let go of their SD650 set? Been looking to buy one, but can't wait for the shipping time, might die haha
mun
ouch!!! =:p
mun
xiaomi sg will be launching next month and will be definitely cheaper than those who bought earlier from other resellers.
Suggest you wait or prepare to pay a higher price if you want it now :s22:
cscs3
Dont think so. Xiaomi note 2 already at $229. Guess note 3 will be in the price range of Mi4i.
