Xiaomi Redmi Note 3
kopi22
Is Gold better looking than the Dark Grey? Only 2 choices available in SG.....
Looks like this phone is bang for buck.
s016
added up also about $320, If you have grabbed $100off500 coupon.(last day)
effectively 20% less, and $10 item coupon, $250 export.
For many $50/17% less may not be worth skipping warranty.
I see. Too bad I do not have the $100 voucher. Cheapest I can find is from Lazada which is 288. Coupled with the Mastercard Friday promo, should be around 268.
swastikas
nope, only 2G for SIM 2 when SIM 1 is on 4G/3G network
Sent from my Rice phone using GAGT
If thats the case, sg 2g network going to be "cut off " in April 2017. Which makes sim2 slot useless for sim card in sg.from 04/2017. I still prefer the independent sd card slot and two sim slot in note2.
Still useful for travellers going to 2g network countries though. Hopfully redmi note4 will have at least sim2 3g network .
amazingone
can use it as an SD card slot too
touchme
Good enough at $268, for silver die-hard.
Hooted at strike of midnight, $313+4 phone and $175+10 e-scooter plus fillers, using coupons/giftcard (3% off), effectively just under $250 all-in for silver.
Pray not tampered MIC set.
Sent from my phone using GAGT
Mng85
dunno can do the hack like s7/edge stick the simcard on the memory card
warr
Hope 2g sim is software restricted, so it could be upgraded to be 3g capable.
.笨 小 孩.;100528344 said:
1 tray with 2 slots only...
slot 1 = ur primary sim card
slot 2 = second sim OR micro sd card
:s22:
so if user is going to use dual sim
then the phone will not have external sd slot
+ the non removeable batt
hai.....
this is a deal breaker
