silverstar
- Jan 21, 2002
hmm they removed this post ...
Google has cached the webpage: http://webcache.googleusercontent.com/search?q=cache:http://en.miui.com/thread-3325066-1-1.htmlhmm they removed this post ...
with so many models coming, which is better buy?
redmi 6 pro, mi max 3, mi a2/lite or note 5
Depends on u. Either get from rwm or newstar.What's the best deal for this?
Saw official stall sells it at 349
Local red white mobile sells it at 288
Newstead sells export set via qoo10 at 215
https://shopee.sg/jtbcgroup/1174865419sic link? cannot find such low price
Posted with HardwareZone Forums app
50/50 chance you'll get a set with a fake rom. Unless it comes with china rom or global.. buy at your own risk. And don't bother to message them as they take ages to reply. Other than that, if no other models have this issue, it's the best offer
Seems like they are selling three versions:50/50 chance you'll get a set with a fake rom. Unless it comes with china rom or global.. buy at your own risk. And don't bother to message them as they take ages to reply. Other than that, if no other models have this issue, it's the best offer
I will only buy from them if they can guarantee a set that comes only with china/global romSeems like they are selling three versions:
- China set with original China MIUI ROM
- Global set with original Global MIUI ROM
- China set with modified MIUI ROM
The review below the modified ROM's review mentioned he got the Global Version aka. Global set.
But @215, what's the configuration? 4+32
The most desired one will be the Global set, as it guarantees you with Global ROM preinstalled with Google Play apps.Which set is the desirable one and why?
Yea , you are right.
their config for 4/64 is $273.80
Storage : 4+64GB
Color : Gold(+$45.00)
Safety Approved Mark Plug : Yes(+$4.90)
Warranty : Free 3 Months
Tempered Glass : Yes (FREE Black TPU Case)(+$8.90)
Black and blue will $10 more
their config for 6/64 is
Storage : 6+64GB
Color : Gold(+$100.00)
$328.80
Pink $5 more , Black and blue will be $10 more
The China set with China ROM is also acceptable if you don't mind manually installing Google Play to the phone.
