Xiaomi Redmi Note 5
Jian19
Brought mine from here...its full covered tempered glass screen protector..not bad
tk
i'm considering to get the Note 5 AI Dual Cam model.. but read online that the MicroSD card uses the SIM2 slot.. so if I use 2 SIM cards cannot put MicroSD card?
cannotliao
China rom also ok lah. Been using it since May.
many seller dumping their china set in carousell by disguise the set as local, cover the box set and focus on global-rom.
When i ask to show pix of box & charger... many patterns come out.
Reason im getting global version aka local version, i need the 4g & lte band 20 as im using starhub/myrepublic.
Many seller twist their words as they unlock lte, unlock baseband. Band20 is hardware based. Dont have means dont have. Some model can unlock but not RN5.
it not only about the ROM
some xiaomi china phone with china ROM dont have LTE Band 20 which will affect the phone in sg network.
Sambuca78
Thanks, bot this from Shoppee at $2 after deducing coins. :D
https://shopee.sg/For-Xiaomi-Redmi-Note-5-Note-5-Pro-Full-Cover-Tempered-Glass-i.39554718.1069578569
PeasantBeing
Yes i thought I'm the only one. Notifications ringed but when waking the phone you don't see it on the lock screen. Need to unlock and pull down the tab
You can set this in settings
Sent from Rocket Uno cruising in Midnight Black Galaxy No. 9 using GAGT
eting72
what's the best deal for 3/32 gb? prefably local as not too familiar on flashing china set
whoooo
Price of a local 3/32 u can get a 4/64 export. I bought a export set already preload w global rom from Qoo10
