Xiaomi Redmi Note 5
KWSquare
Anyone have got any guide to flash OIIMIFA rom to OEIMIFA rom?
Sent from Xiaomi POCOPHONE F1 using GAGT
Pocoyoz
Lazada official mi don't have this phone?
Sent from Pocoyo fan club using GAGT
Lex1989
https://. i.imgur.com/dMxyZcC.png
Sambuca78
Do you guys encounter the missing bottom button bar after updated to MIUI 10?
Need to swipe down the notification bar then the bottom button bar re-appear?
PeasantBeing
You enable full screen display is it?
Mine don't have the bottom bar anymore after I enabled full screen display. Now use gestures to swipe like iPhone.
Sent from Rocket Uno cruising in Midnight Black Galaxy No. 9 using GAGT
Sambuca78
No, i didn't enable the full screen display leh, as I noticed it lagged if i enabled the full screen display. :(
PeasantBeing
Mine's OK. Normally for a major upgrade I will factory reset and reinstall to make sure no problems.
Most likely your problems are due to some app or settings conflict.
Sent from Xiaomi REDMI NOTE 5 on Rocket Uno with Zero1 Booster using GAGT
hiakhiak
They're selling note 5 6/128 on jd.com at ¥1249 now, don't know if they'll go even lower on 11.11... :s22: Anyone using export 6gb set? Does the lack of band 20 have a significant impact? I'm on Starhub but contract ending soon so I might move to Circles.Life.
bladez87
Now on sale at shopee for $218
Sent from Samsung SM-J730GM using GAGT
