Xiaomi Redmi Note 5
bladez87
OMG! Why does my redmi note 5 come with miui 10??? And when booting it up the first time... It showed unlocked at boot up screen!
Sent from Samsung SM-J730GM using GAGT
bladez87
??? Got fake one meh? Anyway, not a big issue for me, just don't use this Healthy 365 app lor. Just find it strange, that's all.
Had been using my Note 5 Pro for close to a month, so far so good everything else. No complaint for a $199 4/64GB phone. It's a definite upgrade from my previous Note 3 Pro. :)
Where u buy 199 64gb? 199 before or after coupon and discounts?
hiakhiak
Seller flashed for you? Check if it's legit, if you wanna play safe, you can flash over before you start transferring your apps and data over.
happyko
Happened to need a phone, saw one with the lowest price at the time of browsing.
So bought it from here
https://m.qoo10.sg/item/XIAOMI-REDMI-NOTE-5-PRO-4GB-64GB-SNAPDRAGON-636-OCTA-CORE-WITH/635113625?jaehuid=2026058764&gclid=CjwKCAiAlb_fBRBHEiwAzMeEdvtB7mWQzNKmcaytDtM9XuAzCkxXUJuZpXK_oqYhmLkoe2bebjADZxoCY24QAvD_BwE&__ar=Y
Got it for $199 after $50 coupon discount previously.
Mine now running MIUI 10 Global Stable ROM V10.0.1.0.OEIMIFH.
bladez87
Ooo... After coupon... OK. Ya. Lazada after 1111 also around 200
Ultimo_Urien
My note 5 pro batt lasted roughly 1.5hrs longer den my new poco F1 sia, even though both have similar batt capacity..been using both alternate days to play games and normal usage till I end work and reach home.
bladez87
The stupid tempered glass for the camera more ex than the phone on lazada... And now shopee min spend 20 for free shipping. $2 shipping for $1 item...
limjialok
Anyone knows the cheapest price in local shop for local and global version of redmi note 5 3gb 32gb?
PeasantBeing
Wait for official shop sale and then go queue a few hours earlier. Last time was $179 sale but people started queuing a few hours before sale start.
Sent from Xiaomi REDMI NOTE 5 on Rocket Uno with Zero1 Booster using GAGT
6 cost nearly 50% more than 5 , for very little improvement
bad buy
Interestingly Challenger store sells Redmi Note 6 Pro for S$329 4GB/64GB Version but S$349 for Redmi Note 5 4GB/64GB.
Spec looks identical but Note 6 Pro has dual front camera and S$20 cheaper.
Krabs.
was comparing export set price 4/64 ~$200 rmn5 vs ~$300 rmn6
limjialok
From what I heard, note 6 dual back camera is exactly the same as the note 5 ai dual back camera right?
Is the note 5 ai only for those box with 小米note 5 at the front of the box? Or the English Xiaomi note 5 text at the front also using the upgraded camera?
I wanted note 6 due to better camera and quick charge 3.0, if global note 5 also have the better camera, note 5 global is a no brainer
SBS2716G
Anyone know where to get cheaper n local set note 5 pro 4+64gb with local warranty?
bladez87
Export set available around 160-170 after coupons on lazada
jas1701
Can also go to authorised xiaomi store have a look. Price should drop by now since note 6 already out. Not sure about store price but Xiaomi Lazada online selling at 279.
Take note carefully of the Lazada online. It must be Xiaomi Lazada.
limjialok
I bought it some two weeks back at $218 at Redwhite Mobile. I think that's about the lowest price so far.
Red white mobile selling 3gb 32gb local set at $199 but it's in blue only. :( I am looking at black or light pink. Any idea which shops sell at $200-$220 local set?
jas1701
Those get from telco re-con sure got alot of unused apps which you don use at all. When try to uninstall it, you cant, only see Force Stop or Disable. After restart phone all running again.
What I do is reset the phone to factory default. Now very clean, no more nonsense apps.
