Xiaomi Redmi Note 5
Tornesoul
No screen protector.
But got transparent tpu case. Case is average thicknesses, good protection, not those ultra thin types.
Sent from Xiaomi REDMI NOTE 5 on Rocket Uno with Zero1 Booster using GAGT
Thx alot.
If u guys were to buy a hp now, would u pick redmi note 5? Or redmi note 6 pro?
Assuming nil phone now.
The redmi note 6 pro just btr camer?
Sent from Samsung SM-A520F using GAGT
Tan_Damian
I using note 5 pro while my maid using the 32gb note 6 pro.
To be honest not much different except the notch design but I find note 5 pro size easier to handle with one hand.
yusoffb01
Thx alot.
i have both. similar camera. if you dont mind notch get 6. if u prefer rounded display edges get 5
yusoffb01
miui doesnt support using adaptive storage, but following this guide i manage to use 128gb card as internal storage
http://en.miui.com/thread-820440-1-1.html
Im using a 90MBps microsd card, so far feels just as fast. download files are 10MBps, copy into phone via mtp 20MBps
bladez87
when i first got my note 5, i was able to connect to the wifi, subsequently, i updated to miui 10, and did a factory reset. after doing so, i am unable to connect to any wifi even though i can see them on my phone.
anyone knows the solution?
shichuanhua
switched to pocophone le.
Letting go Black Note5 6+128 , flashed global rom liao , used for around 2-3 weeks only
$265
with tempered glass & case on liao .
+ spare tempered glass
GenocidalX
Surprisingly I still holding on to this phone.
Shall keep it as spare everytime I selling my main and change to new set.
PeasantBeing
I am still using this phone for my 2nd line which I use more frequently than my main line. No intention to give this up yet as I don't play games and SD636 good enough for me.
maboklee
Same here bro :)
Sent from Xiaomi REDMI NOTE 5 using GAGT
osirisx
Anyone having issue with play store for a China set?
Server busy, please try again later..
Means what?
gab123
i think my usb port have problem, used to take 1 hour 40 mins charge up phone from 20% to 100%, tis 2 days i see the fast charge icon, but takes 2 n half hour to full charge
Teo Ming Ern
Try a different charger and cable first, if possible...?
gab123
change cable, change charger and cable, change another place to charge, also same, than funny today i reboot phone, charging time back to normal, 1 n half hour for full charge from 25% when plug in
