Xperia Arco S
pker88
I managed to do a 1-to-1 exchange for the non-charging Ion. Thanks to the staff at M1 Bugis.
Regarding the SD card, I managed to use a Class 10 64GB on it (cost $122 at Challenger) No problem.
rofl 122$ for a class 10 64gb u paid too premium
now 64gb sandisk already. selling below $100
Matte82
After using this phone for about 5 days, I think the only problems I have with it are the battery life and the earphone cover. Drains super fast for the battery life. The earphone cover seems a little flimsy to me and am extra careful when I'm listening to music. Using more of my bluetooth earphones these days.
Anyone could recommend how to conserve battery life for this phone? Should I invest in getting a portable charger? Any recommendations would be greatly appreciated :)
pker88
try to seasons the battery first. try do drain till 10% or flat then charge back
and. common sense of using android applies
kill the process if u don't need it
and check if u got any appls running back kground drain data
swrich to 2g
lower down brightness
in the end is all due to user fault mostly if battery drain badly
portable charger is a plus to have if u heavy user and no way to charge it
good luck have fun
pker88
test Arco s again at bishan sony
surfing wise still acceptable speeds rendering
offcourse if want compare to Sammy s3 is lost out lor
but sound quality and cam still beat Sammy s3
but if I recall on sony website it state xpreia s battery is abit more longer than Arco s quite is odd as both similar specs too
Matte82
swrich to 2g
good luck have fun
Thanks bro. I'm a noob with Android, so can I ask, how do you check if there are apps running in the background? I only know the iOS method but not Android. Thanks again!
rssd21
Settings/Apps/Running - List of apps running.
Press & hold 'home' button - recent apps - swipe left or right to close it.
Settings/developer options/background process limit - no. of processes allowed to run at one time.
hush66
As pker88 mentioned, you need to let the battery "burn in" for a couple of weeks before it stabilizes.
The earphone cover flap is the reason why I didn't buy the Acro S. I often listen to music using my phone, and I can imagine the flimsy flap would come off in a few months' time.
pker88
looks like bro rssd beat me to it hahaha
yalor the stupid frappy caps
makes it more troublesomeunles u rarely use it to listurn to mp3
using bt earphone is alternative but it drain your battery even
more badly
I burn in mu xpria in less than 3day I find it battery as good as my old arc s even it on a higher specs and larger screen
but my Sammy s3 beat both to it hahhha
bur can't compare sammmy s3 to xperia lor both is diff hardware too
how sux is the camera compare to nokia?
pker88
nokia which model u looking at?
it weak on low light
if got a good light scource is quite good
but sony xperia is stil the better one overall
performance wise sammy s3 is still king
rssd21
No need to compare nokia, does not even have android phones & different hardware levels. Meaningless to compare on unequal grounds or only camera performance on different os. :D
pker88
maybe he is coming from window cmi OS phone lor haah he wanna try a alternative haaha
ragnarok95
Senior Moderator
Senior Moderator
Nokia is sticking to Win 8 phone which will see their hardware side on par with current high end sets this year.
pker88
ya even it coming up a higher end specs the OS is stil like a apple haha
control restirctive mindset over andriod ahahaah
good for those noobs and dont want to mess around with it
and not a power user hahahaa
shawn4881
Hi! i juz gt my acro s today frm Singtel! $47 National Day discount + another $50 discount after callin and requestin frm them. I paid $191 under the 3G Flexi Lite plan and I received $4.70 off my mthly bills for the nxt 24 mths! =)
I wld juz like to check wif the gurus here. How long do i need to charge the phone for the very first time? Thanks! =D
saj282
Got it yesterday.
Very impressed with the crystal sharp and highly detailed display. In spite of the aged Snapdragon S3 SoC used, its UI performance is comparable to the HTC OneX I had owned and the Galaxy S3 I tried briefly. The phone's width is just nice for a comfortable grip with my thumb reaching all corners of the screen. The water resistance capability is an icing on the cake.
hush66
Recommendation is at least 8 hours.
rssd21
Got it yesterday.
At least I can tell you the 3 soft buttons are more responsive than the ones on xs. And flaps on the phone because its water-resistant, unlike xs. It comes with version 4.0 onboard, basically a clean installation of ICS which means less issues compared to phones upgrading to 4.0. Not to mention the material feels better than that of xs, IMO.
saj282
I believe smartphones that are recently released with ICS out-of-the-box are highly optimized for the OS.. so, for those that are released with GB, don't expect better performance/battery-life if the upgrade comes subsequently.
Of course, it's a different story if the upgrade is through rooting..
BTW, loved the stand/charging cradle that comes with the Acro S package (I think this is not included for Xperia S). Courtesy of the side charging contact points on the phone and good design of the cradle, charging the phone is now so convenient and graceful. The USB input on the cradle works with iPhone power adaptor but not with the computer.
Photo image quality seemed good but speed of auto-focus+capture though fast, is still noticeably slower than HTC OneX. The camera options available is mind-boggling.. very similar to those found in my HXV9.
Battery life is average.. after some downloading (~50MB), Surfing and music playing for around 2hrs, it dropped to 75% charge.
