XZ2 Premium
darkmatt
Sony usually is one or 2 gen lag behind in spec especially RAM and storage.
As long as there is SD card expansion will be good enough
apps cannot be installed in sd card.. that is the main issue for me
amazingone
I guess you all are fine with the removal of the 3.5mm port
Sent from Sony G8142 using GAGT
I'm slowly accepting the loss of the 3.5mm jack, I just hope they won't remove the micro SD card slot.
haylui
due to the chipset. xz2p should be much better as it is having larger batt and 845.
Just now went to SingTel shop played the XZ2. The phone doesn't feel like 11mm. Anyway, the grip is so good. And actual phone looks much nicer than in photo..
SeanPC
ergonomic design. i also feel is nice.
technolust
FP sensor placement was ok for you? I found it awkward to reach. The back curved design also makes the grip less secure due to smaller sides. Preferred the older design with side mounted finger print sensors :(
vofzxy
been using wireless all these while in the gym, not an issue to me
Sent from Sony Z4 using GAGT
So sad have hi res audio then remove wired connection
How many wiresless earpieces out there are aptx compatible much less LDAC compatible :(
Laneige
I wonder if it's gd to buy xz premium instead of xz2 premium since prices have dropped for recontract n xz premium is flat surface. What am I missing out if I buy xz premium instead?
Is the recording all still in 4K but maybe not full hd or something?
Wondering what abt apple too. Hmm what abt night pictures?
Thanks
darkmatt
I'd remember z5p still can...
Battery life of z5p is not that good. I hope xz2p would be much better.
android restriction..
last time old versions can install in sd card. now all apps in phone mem only..
very sad
alienjeffman
Thanks
Personally I would go for the XZ2 premium. The XZ Premium is nice but I feel the top and bottom bezels are too big and the corners will make a hole in the pocket.
The XZ already made a hole in the jeans pocket.
Camera wise XZ2 should be better, wait for the review I guess.
rssd21
XZ2P will not make holes in pocket, only bulging pockets. :D
haylui
Thanks
Should buy xz2p because after I hands on the XZ2. The phone doesn't feel heavy and the grip is actually very good..the phone itself looks beautiful in real life than photos.
Some more the camera also better than before. Why buy older model?
