Zenless Zone Zero
rrr2015
combat is fun.
no tips leh..i just try try abit only...still busy.
all charactors have different playstyles.
look like can play in short bursts, for me is a plus.
are u sure u can play in short bursts? mostly long convo in commission though there is skip option fortunately but u lose the story :LOL:
AriesBlack
Anyone experiencing overheating on their phone when playing this game? I'm using iPhone 15 PM...
Trueblue82
https://www.prydwen.gg/zenless/guides/tips-and-tricks
  • Before starting the story you will be able to choose either Casual or Challenge mode. Challenge mode doesn't give you pre-made characters to use and the monsters you encounter there do more damage and have vastly more HP. Overall there's really no reason to pick the Challenge mode unless you want to to well, challenge yourself as the rewards are exactly the same in both.
  • You can change between Casual and Challenge mode on the story screen at any time - so the choice you make initially isn't final.
  • Hard mode unlocks after clearing a chapter and provides additional rewards.
  • Focus on the Main Story first and only start completing side missions when you're forced to level up to unlock the next Main Story zone.
  • Make sure to do all the challenges for the stage. Challenges are basically Stars for the stages, so make sure to do all of them so you do not have to track back and revisit the stage again. Missing out on these stars will also mean you'll be getting less tokens, which are needed to progress further into the story. In different modes they also provide extra materials for pulls or character building.
  • Make sure to do the side missions once you're stuck in story. They will also provide with tokens used for unlocking next zones as well as extra pull resources.
  • Do not forget to visit NPCs such as Coffee shop, The Newspaper stand and your helper Bangboo in your base.
  • You can fuse and dismantle character upgrade materials, so in case if you need to upgrade a new character, just dismantle the materials you got from upper tiers.
  • Do not forget to do your Battle Pass Daily and Weekly missions, they provide pretty decent materials, especially during the early stages of the game.
  • There's a set of weekly rewards you can obtain in Rally commissions, as well as Hollow Zone License Pass, so make sure to do enough runs to get them all.
  • Always do your dailies as they provide a good amount of Account EXP and Polychromes for your account.
  • Don't let your Batteries (stamina) overcap. 240 Batteries is the maximum amount you can store and regenerate over 24h.
  • Decide on what your main team is going to be as early as possible to avoid wasting resources and to be able to better focus on what disk drives to farm for.
  • You ideally want to have a Main DPS, a Stunner, and a Supporter in a team. Your Main DPS will want to use the most on field time during the enemies staggered phase to dish out the most damage basically, other than that you want to parry-swap between the Stunner and Main dps most of the time.
  • You will eventually need a Main Dps for each element, but it's not something you need to worry about early on. Due to how the team building works in ZZZ, you can most often mix them with either the same element or same faction to make use of their passives.
  • Use your Batteries for farming resources early on. You will need a solid bit for upgrading the characters, it can be either EXP for them or the weapons, as well as ascension materials for skills or talents. Do no use them on Drive Disk farming since you only want to start focusing on them once you reach account level 40.
  • In early game level your Main dps to the max level they can be, and the remaining characters in your main team can stay 10 levels below to save on resources.
  • Do not invest in 3 star W-Engines (Weapons) too much as they are just placeholders until you get 4 and 5 star W-Engines.
  • Do not forget to do your weekly boss runs in the Reckless Challenge!
enimen
Which option let's u pull for new characters ah? The menu looks really messy and I'm lost
Trueblue82
don't worry about tier list too much, its important to find a hero that suit your own playstyle.
for f2p just use Anby for stun and Nicole can suck enemies together so they probably pretty useful early on for most ppl.
IndigoEyes
My 5hrs first impression is that the story has a slow start. The story feels like it's going to revolve around commissions which actually isn't my cup of tea. >< Maybe I'm still early in but nothing actually catch my interests yet. I felt so sleepy when I was playing the game. The only good thing about this game are the voice acting and music. I will give it further chances in the weekend.. most likely a short term game.
The gameplay feels very ordinary because I played alot of this genre before hoyoverse made Genshin. This genre is actually common among gacha games. One thing I wanted to say is that since it's same quality as many other gachas, I don't know why all the $ packages costs the same as Genshin. That turned me off quickly. I think those whose only gacha knowledge are from hoyoverse games are not aware that ZZZ is overcharging them lol. 100% not worth spending in this game except monthly and BP passes.
Trueblue82
the first real challenge is the boss at chp 1-5
i think where he has 2 phases and multi hitting atks that require you to dash and immediately parry the atks.
Hisashiburi
im confused about the Q and E... sometimes, auto switch to another character when i use Q/E?
rrr2015
check keyboard mappings?
if play casual mode just unga bunga, if something flashing just follow :LOL:
Zinna
Got the maid from the 50th pull on the beginner banner
Feels casual, can play and see how.
Hisashiburi
Finally got enough to get 10 rolls for the Ellen S limited character and only got an A character... lame
