Windows partition
xxSCARxx
Hi i'm using windows 10 and i want to give my C drive more storage space. How do i go about doing that and i'm using lenovo Y400. thanks
ykgoh
Is your current C: drive taking up 100% of your HDD capacity? Then you need to upgrade to a larger HDD, and clone your data and OS over.
If not, look at software like Acronis or EaseUS Partition Master to resize your C: partition.
xxSCARxx
actually no my C drive has 200GB and D drive has 700GB but i cant seem to move the partition over to the C drive.
albertlee
Just need to resize your partitions, reduce D and increase C volume will do.
mocax
is the bulk of the space on c drive taken up by programs or your documents and pictures?
tungsten2
Pls post a picture of your disk management screen.
-click on "start"
-type "diskmgmt.msc'
Then use a snipping tools to capture and post it here
xxSCARxx
-click on "start"
i already separated 200GB to be put in C drive but i can't seem to merge them together.
ngbc
In between your C partion and the Unallocated 195.31GB disk space, there is this 451MB partition (with 12.59MB used). What is it for?
You can only expand C if you can 'move' that 451MB to immediately before D partition.
Check the video guide to merge partition:
tungsten2
As mentioned by ngbc, just expand your C drive to cover the unallocated space.
albertlee
i've already merged then 451MB and the 195GB together. already
If you want to resize partition C then the only way out is to delete the merged partition first.
Seriously who setup your system for you?
