Any good n cheap tire shop to reccomend ??
Cartoon0512
16" .. No need v branded one .. Heheee .. Got pple quote normal is $120 then what Bridgestone is $135 .. Ok ?? Me asking fr more options ..
CCCustom
Bridgestone what brand ?
Uhh ... Bridgestone brand is ....... Bridgestone?
I'm sure you meant "model" :s13: Anyways, TS should probably be schooled about tyre size/profile before recommending something that might turn out to not be available in his required size/profile? ;)
sinicker
if you just need tyres for your car to move, then can try Guan Lee Tyre at Kaki Bukit Autohub.
Mr Tay serves with his usual warm personalised service and his tyres are affordable.
Kula Diamond
Oops my bad yup model :s13:
Cartoon0512
Okie thanks .. Juz called and he said $125 for 16" .. Sound v nice ..
Cartoon0512
I m not sure what Isit call.. The guy on the line told me normal one is $120 .. Asked me to take $135 dunno what bridge .. Stone .. I dunno tyres name ..
whizzard
Cartoon ah Cartoon ..... tyre must learn because it is very important for your safety as the only thing between your car and the road is your set of tyres.
I go to Eng Wah Tyre & Battery located at Block 5 Toa Payoh Industrial Park. Best price in Singapore and some say Batam .....
Cartoon0512
Hehee .. Firestone $125 .. 16" ok ?
