Cartoon0512
- Jan 5, 2014
Anyone got lobang ??
16" .. No need v branded one .. Heheee .. Got pple quote normal is $120 then what Bridgestone is $135 .. Ok ?? Me asking fr more options ..
need full spec like, 225/55/R16 etc
take a look at ur tyre
If juz normal tire .. I dunno much on tires but the guy said if take Bridgestone only $135
Bridgestone what brand ?
at $135 you can get uhp tyres like Toyo R1R liao
Uhh ... Bridgestone brand is ....... Bridgestone?Bridgestone what brand ?
Anyways, TS should probably be schooled about tyre size/profile before recommending something that might turn out to not be available in his required size/profile? Uhh ... Bridgestone brand is ....... Bridgestone?![]()
I'm sure you meant "model"Anyways, TS should probably be schooled about tyre size/profile before recommending something that might turn out to not be available in his required size/profile?
Okie thanks .. Juz called and he said $125 for 16" .. Sound v nice ..if you just need tyres for your car to move, then can try Guan Lee Tyre at Kaki Bukit Autohub.
Mr Tay serves with his usual warm personalised service and his tyres are affordable.
I m not sure what Isit call.. The guy on the line told me normal one is $120 .. Asked me to take $135 dunno what bridge .. Stone .. I dunno tyres name ..Uhh ... Bridgestone brand is ....... Bridgestone?![]()
Hehee .. Firestone $125 .. 16" ok ?Cartoon ah Cartoon ..... tyre must learn because it is very important for your safety as the only thing between your car and the road is your set of tyres.
I go to Eng Wah Tyre & Battery located at Block 5 Toa Payoh Industrial Park. Best price in Singapore and some say Batam .....
Michelin PS3 ..... dry and wet weather handling very good .....!
Really got this tyre leh .. I tried to surf net n find .. Cos I called up the tyre guy again n he spell Bridgestone ..
