Huawei Mate 8 - The True Successor
moonSymph
Go to settings -> more -> tethering & portable hotspot -> portable wifi hotspot.. from there you can configure the wifi password etc..
guys, how do I tether with my hotspot with Android Marshmello using Mate 8...(sry 1st time android user here)
moonSymph
I dont have such issue.. since you purchase your phone from huawei shop maybe you can check with them?
very happy with the phone. got it from huawei shop in plaza singapura. built is very good. but screen seem to have a slight yellowish tint at bottom left. anyone habe same issue? also what internet browser you guys are using? it seems chrome always have a 1, 2 second freeze before starting to load any website
zhaoshanhe
hi all,
am considering purchasing the telco set when i recontract. can i just check with you guys on the following?
- anyone rooted? can share on the resources and steps?
- if we do not use the huawei supplied charger, but use alternative 2.1A/QC2.0 charger, will it still charge quickly? there is also no way to support wireless charging right?
- any recommendation for casing and screen protector (apart from mobilelite jimmy)? intending to shop bluelight glass SP from taobao if cant find locally or local is too ex.
jazzman80
don't know why the music player jerking on and off despite after a restart. anyone encountered before?
flanket
has anyone try the NFC function with Ezlink application on mate8 to see whether it can read the Transitlink card? I try and don't detect, but the NFC beam work on transfer file to my mate7. The app work on my mate7 running EMUI3.1, no idea is it because mate8 running EMUI4
deckcard
Oneplus One 7.5hr SOT although may not be as good as the mate 8 but can get a used one for less than 300. Pretty good imo
kennyg1969
The ezlink app (my ez-link mobile) worked on my mate 8. Managed to read 2 of my ez-link cards
jazzman80
What happen to the new firmware? Weaker battery life ?
Any idea with heavy gaming this phone battery can last how long ?
On my s7e I can get 7 SOT with 4 hour gaming time
Sent from samsung S7 Edge (Black) using GAGT
no matter what phone, I still believe in sticking with the stock firmware has the best battery.
sorry I don't do gaming but I guess, should be longer on mate 8.
because it has bigger battery with lower (full HD) resolution.
just purely on browsing the internet, I ever hit 15-17hrs SOT.
