I Miss My Nokia 3310
Bring it back ! lets go retro!
Cheers,
tfr :s12:
ykgoh
Now then it starts to make Android phones. Maybe just nice market change again Windows Phone becomes popular... :s39:
Nokia will kick itself again. There is a Android phone fatigue with the market flooded with cheap Chinese phones. Even Xiaomi and Lenovo are starting to struggle to sell more phones.
bro do you think that Samsung will be affected. To be honest i think their phones are not bad but just that is a little pricey. what do you think?
garychengjw
define 'affected'? =:p
samsung not easily 'affected' by nokia.
unless they can be on par with specs/function/quality and cheaper by alot. which i really doubt so. :vijayadmin:
chengsun
Cheers,
tfr :s12:
I am considering buying an export set Nokia 105 to use as a work phone with prepaid SIM, just to receive SMS, and maybe as alarm clock. $28, no warranty, still considering, haha
kitkat2
will not work in singapore after april 2017.:(
kitkat2
which means it is better that I can a phone with at least 3G?
yes, it is...
but beware of credit leak...so make sure data is turned off at operator end if you dont use data.
chengsun
yes, it is...
Which other low cost Nokia 3G phone you would recommend? I only need to use it to receive SMS.
kitkat2
chengsun
check this:
http://www.gsmarena.com/results.php3?sMakers=1&s3Gs=UMTS900&sOSes=1
if you are willing to spend more than $28, you can consider the NS phone 207/208 that happens to be in discussion in this nokia subgroup.
i'm trying to get a 6700 slide because i prefer a more metallic look and support for mini sim.
search high and low, cannot find any 207 locally, not even qoo10 ect. in the end, paid $60+ for a Asha 300. Haha, I think it is an Arab version, coz the key pad got Arab words. Well, still alright.
