jazzman80
- Jan 28, 2006
because we are using local sets. his is Malaysian set.
Is not gimmick n much improved over previous S6e. If one uses it is quite an useful tool
I had both Mate8 m S7e
Overall S7e is a better performance phone, very much better camera n it's display is nicer too. Only it cannot match Mate8 battery life ( for me 10-11 hours SOT) vs S7e (7-8).
How to disable telco bloat apps in Mate8?
For samsung phones, i keyed some number combi in dial pad and switch the code to international and all telco apps will be gone. Can we do that with Mate 8?
For Samsung they call it CSC codes. I changed to stock and it seem to format the phone and got rid of telco apps, no need to disable them. I also think using stock CSC will get ota upgrades faster instead of under mercy of telco
Does mate8 have this I can use?
is the service center still at Clarke quay??
quite irritating when they keep prompting me to close down applications which they feel are draining batteries like whatsapp
Oh and no idea how to disable vibration when typing a message like sms or whatsapp
I had mate 8, lenovo x3, s7e....all fare well for batt.l (i play games heavier) for sure, mate 8 might be better by a little. On top, all 3 processor are top notch. On the lenovo 5000mah or zenfone max...its processor package is weak in comparsion (ok for user with basic needs)Ahh someone with 2 phones on hand can do a better comparison since the usage pattern would be similar.
So if get mate 8 is just for the battery life but aint the Lenovo 5000mAH phone has even better battery life and much cheaper?
2nd day on mate 8
Likes
Shows telco connected for both sim card
Network speed shown
Faster than my HTC honor
Fast finger print log in
Dislike
Certain widgets cannot change size, can only change the overall "size" of the screen in order to get my desired widget sizing.
I prefer the old fashion type of home pages to be widgets only and all the apps icon in the back room.
You can use 3rd party launcher.
Any recommendations please
There are many launchers available in the play store. The most famous and popular one is "Nova Launcher". If you like it, you can buy the "Prime" version.![]()
Thanks! I got the prime version but doesn't seems to be able to set it as the default launcher. Tips please.
