DBS / POSB 20% rebate but capped at 10 bucks. Means you only earn back 2 bucks only? But how they give you rebate?
Good question, let us check on this and get back to you.
I second thisAlso maybe check whether there will be higher limit for DBS Esso MC to pay petrol. Thanks![]()
Yes, and for the moment, until more people are aware of Apple Pay, just say you want to pay by Paywave.Sorry for this noob question...
Is it true that as long as the merchant has a Visa Paywave reader, that same reader can accept Apple Pay?
Yup, as long as it is a contactless terminal.Sorry for this noob question...
If to disable card should be easy I hope as I heard horrer of Us user
Say it change phone or lost phone then how
Since its tie to phone
Hi memoriess,
If you use a DBS/POSB card with Apple Pay, you'll get 20% rebate on your spend, which will be capped at $10. The rebate will be credited into your card account 60 days after the end of the promotion period.
Our promo T&Cs are here - http://www.dbs.com.sg/iwov-resource...ith-ease/apple-pay/cashback_apple_pay_tnc.pdf
Yup, as long as it is a contactless terminal.![]()
I don't get you but you must have touchID to use apple pay, so lost phone ppl cannot use. Once you reset the phone, the card will be deregistered and you can add again
theoretically, yes, anyone with contactless terminals should accept the payment.So actually not just those companies listed in the Apple website can use right? Every shop that allows visa wave can use Apple Pay![]()
yes sir, you are right! thanks for reminding, worth a check if Find my iPhone is turned onSo if use Apple Pay best to enable find my phone in case phone lost or stolen so can clean phone via iCloud
Hi memoriess,
A bit stupid question:
Can you use your plastic card concurrently with Apple Pay?
I'm not able to link my OCBE Robinson Card leh ...
