MS surface pro 4 in singapore?
mindgamey
Those who want to use a portable powerbank to charge ur surface pro 4 (only i5 & i7), this is my solution;
1. Cable
http://list.qoo10.sg/item/DC-5-5X2-5MM-12V-POWER-MALE-JACK-CHARGING-CABLE-FOR-MICROSOFT/440310813?selectedOptions=
2. Powerbank (car batt jumper & laptop charger too)
http://list.qoo10.sg/item/SG-SELLER-6800MAH-15000MAH-38000MAH-MULTI-FUNCTION-CAR-JUMP/414427459
- I m using the white model with Output: 12V2A
- This powerbank saves me on 2 occasions when my car batt flat.
But u all use at ur own risk hor. Dont quote me if ur SP4 uplorry
There is a USB cable with a built in 5v to 9/12v converter selling in amazon.
So you can basically use any mobile phone PowerBank to double up as your surface power bank.
The price of xiaomi powerbank is so much cheaper than those 12v out there.
evq
Got link?
If convert from 5v to 12v, will the current be the same?
mindgamey
Got link?
I go dig out the link.
A typical 5v PowerBank can give out 5w and the surface consume ard 5w if you are doing basic surfing, heavy load will tap the internal battery.
That's a video in YouTube of a person having a homemade cable to charge his surface pro using a 5v PowerBank.
So it will be charging rather slowly but I think it is a good as a battery extender alternative to those $1xx 12v PowerBank.
evq
Ok.
btw, my powerbank was only $60. Got it to jump start my car, then noticed that there's this cable for sp4. So it added the functionality of my powerbank. guess why not. haha
rockingdude
this one?
http://www.amazon.com/Kuncan®-Conve...v converter&qid=1465433543&ref_=sr_1_1&sr=8-1
how to get it in Singapore??
Vulpix
Moderator
Moderator
Did they improve the packaging design yet? I still remember last time see some unboxing videos, some people didn't know the orientation so when open up the surface actually drop onto table. :s13:
evq
Duno how the old package looks like, but now they have tapes to hold all the openings, thus not easy to drop out.
Vulpix
Moderator
Moderator
That's a good way to do it. The SP3 Pro packaging was notoriously bad IMO.
evq
oic. anyway, these tapes can be 'reuse' quite a couple of times & they are still sticky.
Maybe those reviewers are too eager to open their new hoots, became careless while openings. I m guilty of that sometimes.
evq
true. but can tell if it is been opened before if look carefully.
Kegler
Anyone using this for software development? hows the battery life? eclipse, tomcat and MS SQL ?
PC show bundle still available anywhere?
Del_CtrlnoAlt
if a normal PC can do it, then surface 4 surely can.
web development not really graphics intensive, probably if you ask if it runs solidworks/edge or Creo then perhaps will need some testing. I know it surely sucks to run solidworks on a system that uses integrated graphics. Parts ok, Assm die.
GegeV2
Suddenly, my windows store and apps all not working Zzz
Any fixes?
Gareth
Anyone can recommend a good place to purchase surface pro4? Was searching for a deal that can throw in free microsoft office and the keyboard. Thks and appreciate the help.
mindgamey
3d CAD confirm can
