derrickgoh
- Jan 1, 2000
I currently live in a small 3 room flat. The fibre TP is located near the door and my ONT and router are placed on top of the shoe cabinet near the door. I have RJ45 ports in my rooms and these all connect to the router. So when I'm on my Mac, its wired connection. I only use wifi for my phone and since the flat is small, no issues with coverage.
I am planning to move to a 4 room flat in the near future. Its a new flat in Punggol so I guess they should already have some sort of internet access patch panel (or whatever its called) built into the utility closet just like my parent's flat in Sengkang has. Have not seen the physical flat yet so I don't know where this panel is located but floor plan is similar to this:
But if my mum's flat is anything to go by, it should also be near the door. No issue as far as the wired connections are concerned as all new flats have RJ45 ports in all rooms so my Mac will continue being connected to the router via RJ45. Issue now is wifi.
The utility closet door is closed and if the router is placed inside the closet, the range is already affected. Plus 4 room flat is obviously bigger than my current place so I'm pretty sure coverage will be an issue. I'm not keen to use range extenders and besides with the closet door close, I doubt much signals can get out in the first place.
With my limited networking knowledge I was thinking of this and was wondering if its the best solution for my needs or if anyone can offer better alternatives.
Fibre TP and ONT remain inside the utility closet since that's where the internet patch panel is located. All the RJ45 ports in the various rooms terminate at this patch panel so no issues for my iMac. I connect one cat 6 cable from my ONT to the patch panel and another cat 6 cable from my iMac to the RJ45 port in the room. Settled. I assume? LOL!
Now for the router. Obviously bad idea to hide it inside the utility closet so I was thinking of putting it in my living room. I intend to have a TV console cum feature wall. The TV will be mounted on the feature wall and items like Starhub TV set top box, sound bar and my router will be placed on the TV console.
I know some ppl think its ugly with so many devices there but I'm okay with it. Coverage wise should be okay too since the router is not hidden. Plus the living room is probably about as central in the flat as I can get.
Only thing is, unlike my current set up where the ONT and router are side by side and connected by cat 6 cable, for the new set up my ONT will now be hidden inside the utility closet located near the door while the router will be at the TV console in the living room. Quite a distance apart so obviously its crazy to run a super long cat 6 cable.
Since I intend to have false ceiling for cove lights, I guess the best solution will be to ask my interior designer to create one new RJ45 port inside the utility closet and another RJ45 port on my TV console and the wire can run hidden in the false ceiling.
I will then connect one cat 6 cable from the ONT to the RJ45 port my ID newly created inside the utility closet. At the other end, I will connect the other newly created RJ45 port on my TV console to my router. Then any other devices of course will plug directly into the router. I am assuming this works? Or does anyone have better solutions?
A friend mentioned my idea works but suggested placing the router beside the bomb shelter as its more central. Problem is, I can imagine its going to be damn ugly having some sort of shelf on the outer wall of the bomb shelter and placing router, switch, etc on it. Look like some altar table sia. LOL!
So I guess TV console is still the best place to leave the router. And since the AC88U is a decent router, I am hoping the signals can reach to my bedrooms.
