magicfindsheep
- Dec 1, 2006
does anyone know how to portforward this router?
I will be getting this modem for recontacting from 200 to 300mbps. Will be self collecting and installing. Is this modem plug and play? I have a singtel tv STB at home too. The singtel home line is no longer plug into this modem but directly to the ONT? I am currently using aztech 7002.
anyone knows the usb port is a usb2 or 3 port? wanna try the 'nas' feature!
yes, same connections as what they did for aztech 7002. yes singtel home line have to be connected to the ont.
You will be receiving the ac1900 router
Yes plug and play, no need special config.
Initial setup through Wi-Fi can use the provided password located at the bottom of the router to the 2.4/5g Wi-Fi network to setup like New ssid or New Wi-Fi password, otherwise everything is plug and play.
Phone line will be ont. Check with them upon sign up, can shift the service there.
Yeah that's the advantage for home fibre where all configurations are automatically applied. What u need to change is the wifi password and your SSID to make it look fierce..![]()
thanks guys!
Is the ac1900 better than my existing aztech 7002?
i came from a 7002.I would say better, but some user has issues with it and they ain't sure if it router or SingTel backend coc* up.
if u can try to browse previous comments in this post, bit ain't sure if his issues is fixed or not![]()
force 5ghz? just off 2.4ghz and band steeringJust collected my AC1900 yesterday.. plug n play...
Is it better to leave it at auto channel selection or scan and fix on a relatively isolated one?
Is it possible to force a device to connect on 5GHz band?
