What's the difference between conduit and casing? I'm not doing any false ceilings leh.. v old styleI didn't dare to hack walls to conceal wires.. Because almost all of my walls are the structural walls bold in the floor plan
Wanted to use conduit instead of Casing also but electrician say cannot especially if got lots of wires going in the same direction (eg 7). For conduit, best is can use false ceiling, so like travelling from db to kitchen, can use false ceiling to hide, then conduit go down to the socket etc. That's was his advice if I wanted to do conduit
Sent from Meizu MX4 PRO using GAGT
My wife doesn't want a hood also. My cooking area next to windowsWhy you guys want to have hood? My mum who cook every day think hood is a nuisance. Too much cleaning
Sent from . using GAGT
Wah so all electrical wires start from DB box? I don't want false ceiling leh.. I want to hack and conceal wires..I didn't dare to hack walls to conceal wires.. Because almost all of my walls are the structural walls bold in the floor plan
So must hack from DB to kitchen? My house about 30m or more long leh..
So in simpler terms means hack all the way from DB box to the end of house and encase these wires in concealed conduits?All wiring originated from the DB and they are wired in loop. So for your case, you are just replacing cable trunk with hacking. Below is just an example, it will be alot more wire in real.
Could you share with me your research and the area I should watch out for?
So far my research is only on Landed, Principal Garden area and HDB flat.
can add in,Any interior design firms to recommend?
i don't want contractors.
Please recommend....thank chiu berry much.
Interior Design firms blacklisted in my list.
• Rezt & Relax
• Ciseern interior
• Unimax Creative
• Orange Cube
• Homeworkz Interior
• Weiken
• Rezt & Relax
• Ciseern interior
• Unimax Creative
• Orange Cube
• Weiken
What's ur budget?I am keen in conservation house.Could you share with me your research and the area I should watch out for?
his budget probably 200 to 300 k
