How much did u spend on renovation for ur house?
FT PRIDE
Why you guys want to have hood? My mum who cook every day think hood is a nuisance. Too much cleaning
americanhippo
I didn't dare to hack walls to conceal wires.. Because almost all of my walls are the structural walls bold in the floor plan
Wanted to use conduit instead of Casing also but electrician say cannot especially if got lots of wires going in the same direction (eg 7). For conduit, best is can use false ceiling, so like travelling from db to kitchen, can use false ceiling to hide, then conduit go down to the socket etc. That's was his advice if I wanted to do conduit
Sent from Meizu MX4 PRO using GAGT
What's the difference between conduit and casing? I'm not doing any false ceilings leh.. v old style
My wife doesn't want a hood also. My cooking area next to windows
Sent from . using GAGT
moozmoow
decided on having a hood because i didn't want the smoke or whatever stuff to splatter onto my cabinets. at first i was thinking don't want a hood, place a glass or stainless steel panel below the bottom of the top cabinet. Got a cheap hood in the end because the steel or glass panel would cost about the same as the hood. most likely won't turn on also lol.
jjcc888
We hv never ever had a hood
Think so long as no cabinet above the stove or hob area, should be fine even tho mom cooks daily
TS go to the House of Turquoise blog for ideas on your kitchen backsplash etc
moozmoow
conduit is this type, the black piping on the walls/ceiling (normally people go for black conduit, although have white/grey conduit)
casing is those old type white box
Image found on google
americanhippo
Wah so all electrical wires start from DB box? I don't want false ceiling leh.. I want to hack and conceal wires..
So must hack from DB to kitchen? My house about 30m or more long leh..
moozmoow
if don't want casing and you want to conceal, i think need to hack a "drain" from DB to kitchen, it gets easier when the wires all split to their rooms, but the bulk will be at the DB box there
of course i might be wrong, since i chose casing and didn't experience this
FT PRIDE
All wiring originated from the DB and they are wired in loop. So for your case, you are just replacing cable trunk with hacking. Below is just an example, it will be alot more wire in real.
light-wiring-diagram-If-you-are-new-to-lighting-circuits-this-is-a-good-place-to-start-Here-we-will-explain-how-the-most-common-lighting-circuit-works.jpg
americanhippo
So in simpler terms means hack all the way from DB box to the end of house and encase these wires in concealed conduits?
popdod
Any interior design firms to recommend?
i don't want contractors.
Please recommend....thank chiu berry much.
:crazy: :( :crazy:
Interior Design firms blacklisted in my list.
• Rezt & Relax
• Ciseern interior
• Unimax Creative
• Orange Cube
• Homeworkz Interior
• Weiken
:vijayadmin: :mad: :vijayadmin:
tfkmueh
:crazy: :( :crazy:
• Rezt & Relax
• Ciseern interior
• Unimax Creative
• Orange Cube
• Weiken
can add in,
Chew Interior Furniture Mall, not interested in anything below $40K, too expensive.
Absolook Tradehub 21, reject all your designs more interested to sell u their package design/look.
Ciseern Expo Exhibition, too overpriced for same work quote.
all is based on my 1 time walk-in interview/RFQ i done for my home reno in 2013-2014 period.
DEATHANGELX
:crazy: :( :crazy:
• Rezt & Relax
• Ciseern interior
• Unimax Creative
• Orange Cube
• Weiken
I would like to recommend my own company haha!
