xtramadness
- Mar 4, 2009
I'm on 64GB P9 and tbh i didn't notice the HiVoice at all
Dunno leh... It appeared only after update... Hmm... Maybe cuz u gave all permissions at the start.
Anyone knows where to get the 9V/2A quick charger in SG?
I'm looking for one too. Saw one at Qoo10 "Choetech" 6 port charger, it has 9V/2A output but not sure whether can support P9 plus fast charging. Was thinking of getting it but quite expensive Sgd$49.90. Also saw Sim Lim Sq accessories shop selling "Mercury" 6 port charger which also has 9V/2A price same at Sgd$49.90.
I think they are priced that way due the number of ports. Anyway, if I can't find it here, I will probably get the original quick charger from Taobao as I can live with just 1 port.
i think can consider the anker wall charger from qoo10
support quick charging
FYI, p9 doesn't have qc2.0 or qc3.0, so using a qc2.0 or qc3.0 charger will not speed up charging
using the mate 8 quick charger does work...
http://chinese.engadget.com/2016/05/09/huawei-p9-review/
I'm not so sure how 'quick' do you guys want your charger to be, because for me 5V/2.4A are quick enough for a significant top up of battery juice in an hour. unless you guys are talking about 80% top up in less than 1 hour time.
P9 plus can use NFC for Dash, Andriod Pay etc?
Anyone tried and tested?
Hi does anyone know where the whatsapp directory on p9plus is? Can't find it for some reason lol. Or can someone point me to an easier way to restore chat history from another device?
In your old device... choose backup to google drive.. and do the backup..(basically in your old device whatsapp go to settings ->chats -> chat backup and press backup) then on your new device put in simcard and install whatsapp.. they will ask whether you want to restore from backup(google drive)..
Hey thanks for the tip! Can it still be done this way if i have already started using whatsapp on my new phone?
Huawei quickcharge 2.0 is 9V/2A.. my P9 plus from flat to 100% about 1hr+..
Yes. In fact is same speed as those phone claim to support qc2.0 or 3.0 with 12v but at 1.5A only. Both are rated at 18Watt anyway.
