Huawei P9 - Change the way you see the world. #OO
wmfoong1
Anyone knows where to get the 9V/2A quick charger in SG?
I'm looking for one too. Saw one at Qoo10 "Choetech" 6 port charger, it has 9V/2A output but not sure whether can support P9 plus fast charging. Was thinking of getting it but quite expensive Sgd$49.90. Also saw Sim Lim Sq accessories shop selling "Mercury" 6 port charger which also has 9V/2A price same at Sgd$49.90.
Toby88
I think they are priced that way due the number of ports. Anyway, if I can't find it here, I will probably get the original quick charger from Taobao as I can live with just 1 port.
ze3roo
i think can consider the anker wall charger from qoo10
support quick charging
qyc_91
I'm not so sure how 'quick' do you guys want your charger to be, because for me 5V/2.4A are quick enough for a significant top up of battery juice in an hour. unless you guys are talking about 80% top up in less than 1 hour time.
moonSymph
I tested that my P9 prototype (the 64gb ones) are able to use huawei quickcharge.. when plug in my p9 plus it will say fast charging.. and the charging is really fast just like when i use it on my p9 plus.. but my is the prototype.. i need to test again when i meet my friend so i can use his p9 to test using my p9 plus charger.
FYI, p9 doesn't have qc2.0 or qc3.0, so using a qc2.0 or qc3.0 charger will not speed up charging
using the mate 8 quick charger does work...
http://chinese.engadget.com/2016/05/09/huawei-p9-review/
moonSymph
Huawei quickcharge 2.0 is 9V/2A.. my P9 plus from flat to 100% about 1hr+..
moonSymph
Androidpay cant use yet.. seems to be something to do with EMUI 4.1 and google androidpay.. basically when we try to add a cc the app will check the phone.. which will then prompt an error.. my mate 8 using emui 4.1 have such issue too.. but some other kaki using emui 4.0 on mate 8 are not affected.. give huawei and google some time to fix the issue and we should be able to use androidpay..
P9 plus can use NFC for Dash, Andriod Pay etc?
Anyone tried and tested?
caterham7
black & white
last photo taken using monochrome sensor; 1st 2 converted to b/w in instagram
more photos at https://www.instagram.com/evozero/
if you like these photos, can consider voting; you also stand a chance to win a P9
http://campaign.hardwarezone.com.sg/HuaweiP9/testimonial.php?review_user=5
Lexyyy
Hi does anyone know where the whatsapp directory on p9plus is? Can't find it for some reason lol. Or can someone point me to an easier way to restore chat history from another device?
moonSymph
In your old device... choose backup to google drive.. and do the backup..(basically in your old device whatsapp go to settings ->chats -> chat backup and press backup) then on your new device put in simcard and install whatsapp.. they will ask whether you want to restore from backup(google drive)..
Lexyyy
Hey thanks for the tip! Can it still be done this way if i have already started using whatsapp on my new phone?
qyc_91
has it been backed up on the previous phone? if yes it'll auto prompt you to restore the backup.
cscs3
Yes. In fact is same speed as those phone claim to support qc2.0 or 3.0 with 12v but at 1.5A only. Both are rated at 18Watt anyway.
xtramadness
Yup, but as tested, they wont work on the P9. Both Samsung's Fast charge and Qualcomm Quickcharge. Only powering 5V (and not 2A to it even though they are fully capable of doing so)
